Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X3 F25 (2011 - current)
The latest X3 brings added style and new features to the BMW's mid-sized SUV. Talk about the BMW F25 X3 with other X3 owners now!
Old 07-15-2011, 12:27 PM
dtc100 dtc100 is offline
Mein Auto: 2011 328i
How much does the sport package improve the ride in X3?
I got to test drive a standard X3, was a little underwhelmed. How much will the sport package or the m sport change its driving dynamics?
I know it is not fair to compare a crossover to a sport sedan, but I'd like to have a much sportier X3 than the standard package can offer.
Old 07-15-2011, 01:02 PM
AzNMpower32's Avatar
Tar Heel Faithful
That's a good question, as practically no dealers will pay to equip their inventory with an option that 99% of test drivers won't notice. There are a few folks with the option though (via orders).
Old 07-15-2011, 03:02 PM
Want the Thrill Want the Thrill is offline
Mein Auto: 2011 X3 35i
Sport mode on the 35i tightens up the steering and firms up the ride quite a bit. Not cushy at all when in sport mode.
Old 07-15-2011, 09:33 PM
Does that require the Dynamic Handling Package?
Old 07-15-2011, 09:56 PM
Tar Heel Faithful
Not necessarily. Driving Dynamic Control (and respective button on the shifter console) comes with the Sport Automatic Getriebe and allows for alteration of throttle control, shift points, and steering.
The specific option you are looking for is the Dynamic Damper Control (SA 223) that also allows for alteration of suspension settings via the same button on the shifters.
BMW NA has done to considerable lengths to tailor option packages to suit dealer and US market preferences (namely, big wheels and sporty accents without the "real" sporty handling). So naturally it's gotten confusing.
M Sportpaket and Sport Activity Paket are appearance only. There is no suspension upgrade. The former also requires the Premium packet.
Dynamic Handling Paket gives you the Dynamic Damper Control, rear diff (Performance Control), and steering upgrades (Sport Steering).
Old 07-15-2011, 10:53 PM
No. If you get the sport activity packagen the 35i, you can change from normal to sport, to sport + mode. The I-drive shows the suspension change to sport mode which is stiffer and the steering becomes more tight. Check out his link on the forum as this topic has been debated at length and has been explained by a few members here very well:
http://www.bimmerfest.com/forums/sho...highlight=mole
It should help you when making your decision.
Old 07-16-2011, 07:12 AM
After reading that thread, do I get this right?
If I order a 35i, adding the SAP will give me pretty much all the performance enhancing features as a daily driver.
But if I order a 28i, must order both the SAP and the DHP for those features.
Old 07-16-2011, 07:21 AM
Correct.
Old 07-16-2011, 08:01 AM
Correct.
Thank you, wasn't sure I was reading everyone correctly there
Old 07-16-2011, 09:43 AM
DaleWA DaleWA is offline
Mein Auto: 2004 Z4 3.0i/2011 X3 35i
AznMpower32 is more correct.
X3 35i has 3 available dampers: base, sport suspension and DDC. MSport without DHP has base dampers. There is no electrical connection to vary the damping rate. How do I know? The part number on the dampers on my car (MSport 35i w/o DHP) are the base damper part numbers. That said, I'm happy with the ride after coming from an E46 Sport Package, but have not had an opportunity to push it. It's definitely softer and pitches a bit under acceleration and braking.
2004 Z4 3.0i / 2011 X3 35i
Old 07-16-2011, 10:11 AM
So a 28i with SAP and DHP would have them all, albeit with a less powerful engine.
Old 07-16-2011, 11:32 AM
Tar Heel Faithful
Yes.
Old 07-16-2011, 01:25 PM
Originally Posted by AzNMpower32 View Post
Yes.
One thing I must say though, trying to convince the wife to move from the GLK350 to the X3 will be a tough job. Not only is the GLK sticker $5k less than a similarly equiped X3 28i, it also has a much more aggressive lease program than the X3. Not to mention most X3s are shipped to China, the supply is so tight here there are no deals.
The X3 has to really impress me in the handling department to have a shot, which will likely require DHP, yet there is none available to test drive.
Old 07-16-2011, 02:37 PM
No12 No12 is offline
Mein Auto: 2016 340i xDrive MPerf EB
Having driven the GLK on several separate occasions, in both urban and rural settings, I can say that the GLK feels like a heavy truck compared to either X3. I could not believe how sluggish the GLK felt to me.
But if your wife insists on the GLK and you're stuck with it, suck it up and move on - there are worse vehicles.
2016 340i xDrive EB MPerf
Plus 18 other BMWs since 1971..
Old 07-16-2011, 02:48 PM
Between a base engine X3 without the sport pack, and the GLK, the difference in handling wasn't so obvious, which is why I want to find out how much improvement the SAP and DHP can have.
I knew if I asked her to test drive a base X3 with the standard suspension, it would have been a waste of time.
Old 07-16-2011, 03:16 PM
Have her drive a 35i with the sport activity package and put it in sport mode while driving it. If that doesn't sway her DHP won't either.
Old 07-16-2011, 05:44 PM
I like the idea, I was thinking how was I going to find a 28i with SAP and DHP to test drive anyway.
Now is it fair to say if she likes the 35i with SAP, it is safe to order her a 28i with SAP and DHP, and still be able to sleep in the same bed with her?
Old 07-16-2011, 07:07 PM
I beg to differ. I drove a 28i, no sport, shortly after I drove a GLK. The GLK still felt "trucky" and sluggish. Against the 35i with sport, different worlds, totally.
Check this out: http://www.thetruthaboutcars.com/201...s-benz-glk350/
Old 07-16-2011, 10:52 PM
I will definitely find a 35i SAP to drive.
Old 07-17-2011, 10:32 AM
BruceOmega BruceOmega is offline
Mein Auto: 2008 535Xi, 2006 X3 (wife
Thank you for providing the missing link- a data point from BMW that clarifies the issue.
The only other reference I've seen from BMW is a post in another forum of an email response from BMW NA explicitly stating there are no adjustments to the suspension unless you have the Dynamic Handling Package.
What is interesting is I have not seen any disagreement that engaging Sport mode via the rocker switch does make a difference in driving feel, independent of whether the vehicle has DHP or not, and just how much of a difference the addition of DHP makes.
Bruce
2013 335i xDrive, Mineral Grey, Sportline, Black/Red leather, Dynamic Handling, Shockware, Sport AT, Performance Tires, Increased Top Speed, Premium Pkg, Cold Weather Pkg, HK audio
2011 X3 35i, Titanium Silver, Black Nevada, Fineline Wave Wood, Premium, Technology, Cold Weather, Dynamic Handling, Sport Activity, 19" wheels, Premium Hi-Fi, Sat Radio
Old 07-17-2011, 10:42 AM
Tar Heel Faithful
It is disappointing how un-detailed the BMW NA website is (like that's new news). The German brochure AND Configurator on BMW.de are explicitly clear on what changes when specific options are chosen so there's no confusion as to what you're getting. The level of detail is excellent and given how many models and permutations are available in Germany, some folks must have taken a lot of time to iron those items out!
Old 07-17-2011, 11:23 AM
Thank you, did not realize there was explicit information on the German website.
I'm surprised BMW hasn't provided more details on the US web site. If they had a better explanation of the differences between non DHP and DHP, they might get more people opting for DHP.
Bruce
Old 07-17-2011, 11:51 AM
mspringer mspringer is offline
Mein Auto: M3 & X3
DTC100
I just took PDC delivery of a 35i with sport package and DHP. When testing prior to ordering I was fortunate enough to be able to try cars with the base, the sports, and sports + DHP packages. Like you I found the base suspension to be under-damped, and had a similar experience with the sports suspension (which I believe is identical to the base - see realoem.com). In any case both lack active suspension components so I don't see how changes in chassis stiffness is possible on going to sport mode in the SAP car. I ended up choosing to order DHP since the adjustable shocks reduced the under-damped condition in the sport mode. I got the sport package for the seats and paddles. My experience after driving the car for ~ 1000 miles is it's under-damped in normal mode, and the extent of under-damping is reduced by going to sport mode. Will it be acceptable to you? Only by finding one to try will you know for sure.
Marty
Old 07-17-2011, 12:49 PM
zak52 zak52 is offline
Mein Auto: BMW X3
I have the 'dynamic package' on my 2.0d F25 and it feels tighter than the demonstrator I drove. Little body roll, nicely controllable on bendy roads though maybe a tad choppy on uneven tarmac. Seems great on unsealed roads though, soaking up minor uneveness well, you hear the surface noise but the car rides nice and smoothly, encourages you to go faster! The car has 18inch alloys and the 8sp auto. Can't fault the thing, much nicer than the Land Rover Freelander I test drove, though maybe not as competent off-road.
Old 07-17-2011, 04:10 PM
Originally Posted by mspringer View Post
DTC100
Marty
OK thanks. This makes finding one more difficult since I have yet found one with DHP that was not a special order, meaning could not test drive it.
