Old 07-18-2011, 02:31 AM
tetno tetno is offline
Mein Auto: Z3 2.0 1999
Z3 M52TU still rattle after a lot of replacements :((((((
Hi
I'm new to the formu - and new to the BMW. 2 months ago I bought Z3 2.0 1999 in really mint condition [ 65000 km mileage ]. Problem is almost from the begining i'm fighting with very anoying rattle at startup.
1. It happens in warm-up phace. A start there is no rattle, then when the temperature is in 1/4 it starts to rattle while i add some revs [ around 2k ]. At idle there is i think no rattle. Then when the car warms up completely rattle is gone.
2. What was changed:
- new vanos unit
- side chain tensioner
- water pump
- belts etc
- sparks
- oli [ 0w40 mobil 1, car was driving on it whlie i bought it ]
- top tensioner / chain were inspected
- DISA was inspected
I'm lost with no ideas and BMW service is not helping either [ ther apear to work by procedures only ].
Here are 2 videos from yesterday. You can hear it better on second one i suppouse:
What do you think? Sound for me apears to be comming from or under intake manfold - but i may be fooled.
Bests
Old 07-18-2011, 05:14 AM
RacerXTreme7 RacerXTreme7 is offline
Mein Auto: Z3 Coupe
Get a mechanic's stethoscope and start probing. That will narrow it down to the actual component or at the very least an area.
~Mike....
Old 07-18-2011, 09:49 AM
Hi
They did it today. And after it - no clues (((. They suspect:
- intake manfold - in 2 days they will disaseble it to check it and look inside the engine + check pressure regulating valve
- lifters - is there a way to rule them off/test them??? [ shouldnt these be loud already at start ?? ]
Bests
Old 07-22-2011, 12:30 PM
mr_bean mr_bean is offline
Mein Auto: 2000 328i
VANOS rattle!
Even though you said the VANOS was already replaced, I'm assuming it was only the hydraulic unit that was replaced. The VANOS rattle originates from the mechanism inside the cam sprockets. A stethoscope will help confirm this.
The fix will be to either replace the sprockets or try the Beisan fix.
Old 07-25-2011, 02:48 AM
Whole number 1 on this diagram was repaced. Sound didnt change a bit:
http://www.realoem.com/bmw/showparts...70&hg=11&fg=15
Also last week service checked whole intake [ dismounted it ] and found nothing .
Current ideas are bad chain guides [ they looked at chain only from top previously ] or rattling lifters [ but shouldnt these sound different ??? ].
Bests
Old 07-26-2011, 10:40 PM
DKane DKane is offline
Mein Auto: '97 2.8 Z3 bg R
are you sure that's the right oil ?....and..
is it to the proper level?...On the m52, if the oil level is even a quart low, you can hear an awful rattle up front and low(it's horrible!)..but completely disappears when oil is truly topped up(just over 7 quarts)...some owners even add oil slightly above full(NOT much, just slightly!)...perhaps the TU has a similar characteristic?..Hope you find the problem and if you do, why not mention it when and if?...Z3Cheers! dk'97 2.8 bg R, +1
DKane
Old 07-27-2011, 01:35 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
My M54 is like that too
mujjuman
Old 08-01-2011, 09:15 AM
Hi
First some info - oil level is max, regarding Mobil 1 0w40 - dont know if its ok oil but it has all the certificates and Mobil recommends it for M52TU.
I've been in new service just to double check the problem and currently both places suggest 2 options:
1] - change the oil to Castrol 10w60 [ Edge / tws ]
2] - inspect / replace chain + guides
Number 2 is a bit $$$. What do you think?
Bests
Old 08-01-2011, 10:28 AM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
Originally Posted by tetno View Post
Hi
BMW USA recommends Mobil 1 0w40 for USA cars -
http://www.bmwusa.com/Standard/Conte...ngineOils.aspx.
Might be an interesting experiment. But a heavier oil would just mask, not solve, the problem.
Bests
They are just throwing your money at the problem.
Old 08-01-2011, 09:40 PM
tappa tappa toit
Mein Auto: hoopty
10w60 is a bit too thick though, right?
mujjuman
Old 08-02-2011, 01:02 AM
I bit thick - but still BMW allows 10w oil in Z3 [ car instruction data ].
In general problem is no one knows whats going on . At least 5 mechanics heard / checked the problem in 2 different places [ half of them with long BMW experience ] and there is no clue what to do . As you seen in previous posts a lot of parts were replaced and still nothing. So i'm left with giving up [ but this will destroy all fun with driving this car ] or going deeper.
Maybe its natural ??? - anyone has Z3 2.0 and could do a test for me?
1. Start a cold car [ after night ] or after minimum 2 hours breake
2. DONT REV it over 2k from start
3. when temperature reaches 1/3 of the whole scale [ after blue zone and nearing normal top position ] start to gently rev the car up to 2000-2500
4. In my car there is a rattle now - whats with yours?
Bests
Old 10-26-2016, 11:05 AM
GK12BMW GK12BMW is offline
Mein Auto: BMW Z3 2.0
Hi there,
I just read your thread and I have the exact same sound/problem.
At start up the sound occurs for two seconds and goes away but when I rev the engine it comes back around 1500 to 2000 rpm. It is coming from the vanos and I know this for sure because the sound appeared directly after I performed the vanos seal repair from Beisan.
I replaced:
Vanos seals, anti rattle kit
Water pump
tensioner pulley's
Oil is up to the max(shell helix 0W40)
I did some thinking about the vanos system and I had the following ideas.
1. The oil drains out of the top of the engine leaving room for the vanos pistons to move. Since the vanos pistons are connected to helical gears(they have quite some play) the noise would be gear chatter. When the top of the engine fills up with oil the gear chatter noise is reduced by the oil.
2. The oil pressure is too low. Just after start up the oil isn't warm and oil pump has a hard time to pressurize the system. Since the vanos needs high pressure oil it takes a while to fill up the vanos system. Since the vanos cylinders aren't full there is room for movement.
The strange thing is that I also have another noise. This noise occurs when the engine warm is. Thirst I let the engine idle causing the rpm's to drop below 800 then I rev the engine quick(not hard) and I hear this strange noise coming from the drivers side under at the back/under the intake.
Did you ever find out what it was?
Thanks in advance
