Old 07-25-2011, 02:54 PM
KenTenn KenTenn is offline
KenTenn
Mein Auto: '06 M Roadster
Z4M - Cooling Issue
Just added about 1 liter of distilled water to expansion tank on my 2006 M Roadster (62k miles). I haven't seen any sign of leaks, but that seems like a lot of water to add. Any thoughts?
Ken Lewellyn
'06 Z4M Roadster
'03 Z4 3.0L Roadster (Sold)
'00 Z3 2.3L Roadster (Sold)
www.woodenmachinistchest.com
Old 07-25-2011, 05:02 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Did you get an alert or just checking the cold reservoir routinely?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 07-25-2011, 06:28 PM
KenTenn
The amber warning light would come on occassionally for a couple of minutes and then go off once the engine ran for a short time.
Ken Lewellyn
'06 Z4M Roadster
Old 07-26-2011, 10:12 AM
KenTenn
Well...finally found capacity for cooling system (10.7L) so adding 1 L is about 10%. Not too bad considering I probably haven't checked it in 2 years...I need to flush anyway, but I wanted to make sure I didn't have a leak BEFORE I put new coolant in.
I am thinking about putting the heavy duty water pump, thermostat and a new reservoir tank on. Is that overkill?
Ken Lewellyn
'06 Z4M Roadster
Old 07-26-2011, 10:51 AM
thekurgan's Avatar
Bad Lieutenant
I don't think there is a better pump/thermostat for the S54; it's not like the older, non-M engines where the Stewart is THE pump to have. Reservoir tank should be fine, were you looking for a larger one? The one upgrade I wouldn't mine having are silicone hoses.
Ilse
Bruna
BMWCCA #453648
Old 07-26-2011, 01:05 PM
KenTenn
I thought that the water pumps were only good for about 60k miles and that the Stewart was the pump of choice. Also thought there were a number of premature expansion tank failures so it was best to replace before it failed. Am I confused again...?
Ken Lewellyn
'06 Z4M Roadster
Old 07-26-2011, 01:27 PM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
Well, here's a report of a Z4's expansion tank cracking - http://www.bimmerfest.com/forums/sho...d.php?t=406792
Which would you rather risk? Unnecessarily replacing expansion tanks or a cooling failure.
Old 07-27-2011, 10:38 PM
jsc's Avatar
jsc jsc is offline
Mein Auto: E85 M-Roadster, E82 135i
Z4Ms use a completely different remote expansion tank that is more substantial than the radiator attached one on the Z4. The Z4 ones are the same design as the problematic E46 ones, the Z4M ones are not.
Old 07-28-2011, 07:23 AM
Ron Stygar's Avatar
19,585 Miles
RMFD Water pump $468.45 retail.
It may last since it doesn't have a fan on it.
Old 07-28-2011, 07:48 AM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
$468 for a water pump? This seems obscenely expensive....
Old 07-28-2011, 10:08 PM
KenTenn
Ron: I found the Stewart for $195. Will it work? If so, is it a good choice?
Ken Lewellyn
'06 Z4M Roadster
Old 07-28-2011, 10:34 PM
Ron Stygar's Avatar
19,585 Miles
I didn't thing they had one for S54.
Old 07-29-2011, 08:32 AM
KenTenn
I think you are correct. Just took another look at their site and didn't see S54.
Ken Lewellyn
'06 Z4M Roadster
