7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
Rear Sunshade Broke!
It has been brutally hot in the Dallas area over the past few days...(23 straight days of 100F or higher). This has finally taken a toll on the two little pastic pieces that attach the rear sunshade to the metal levers that pull the shade up or down. The shade has retracted but I can still control the metal levers up or down.
Is this something relatively simple to fix or a situation where the entire assembly has to be replaced? Any help is appreciated.
2007 750Li Luxury Seating package Premium Sound Package Rear Entertainment package |
You can definitely repair this yourself. It should be easy. You just need some plastic glue..or even something like crazy glue should work. You can open up the rear door panel. There are 3 screws that need to come out then the panel just pulls straight out because it is just held by clips.........there is a DIY on here from keif that shows how change the "bowden cable" that shows how to remove the door panels.
The little plastic piece can be split apart into two halfs. Once the door panel is off you will see the shade retracted. You can then grab the end of it and place it inbetween the plastic piece and glue it back together. I have had to do this on one of my shades. Its really not that hard once you get the panel off
I think that is the one he's talking about. Ive been missing the main right passenger shade and I've seen quotes of $730 =[
www.fquick.com/N62B44_SGM 2005 BMW 745Li E66 Sterling Grey Metallic / 35% Tint (windows) / 20% Tint (tails) / ACS Roof Spoiler / Interior & Exterior LED's / MTEC V3's / 6000K D2S / DDM Tuning HID 6000K Fogs / BIMMERFEST license plate cover
Seems like he was talking about taking door panel off. wouldn't need to do that for rear shade i dont think??
I was referring to the rear shade for the back window not the door shades. Any assistance or DIY tips is appreciated.
Sent from my Desire HD
2007 750Li Luxury Seating package Premium Sound Package Rear Entertainment package Last edited by My750Li; 07-27-2011 at 03:59 PM. |
Oh man...sorry I didn't read the post carefully. That one might be hard to get to
Here is the link, good luck.
2005 745i w/ Convenience Package, Luxury Seating Package, Comfort Access, Cold Weather Package, 19" Alloys, SAT/HD. |
Havnt had this issue but that was a great video and will save tons of cash.
Thank you so much! This will certainly make my day if it works. I'll let you guys know how it goes
Would be nice if you can create your own DIY video and post it
Broken Rear Sunblind Fixed!
I just want to report back that I have gotten my rear sunblind fixed! Thank you for suggesting the All German Auto Youtube video. It literally saved me hundreds of dollars compared to taking the car to stealership for repairs.
Although the product worked as advertised, I believe there is a little bit of exploitation on the part of All German Auto. Simple parts like that should not cost $119. But hey I can't complain, that's better than paying $1800 for OEM repair. At any rate, you guys should know that the procedure outlined in the video is not a "one-size-fits-all" for every BMW. I don't know what BMW model that was used in the video but it sure wasn't 2007 750Li. I made the mistake of following the installation procedure exactly as outlined in the video/manual. That made reattaching the blind to the control arm a bit difficult. So my advice is this; if you have a 2007 750Li and you want to perform in-car repair, DO NOT attach the slider (the black plastic peice) to the control arm first as instructed in the manual! Instead attach the slider to the blind assembly first and then connect the slider to the control arm. It is much easier to secure the slider to the control arm with the supplied rivets than doing it the other way round. If you follow the procedure outlined in the manual, you will have a hard time putting back the screws that secure the control arm to the blind assembly. Taking out the whole rear sunblind assembly from the car is probably the easiest way to perform the repair but who wants to go through all that?
Again, glad it worked out for you.
Thanks for the link. Mine broke a few days ago as well because of the high Texas heat in Houston. This internet thing is really cool and just might catch on in the future; I am always amazed at what you can find.
Ours is screwing up too. I'm getting it tinted all around today, so having heavy 2nd thoughts about spending the cash to repair. I probably won't do it, but may try to repair it myself.
RomeClaire
Excellent post!!! Thanks!!!
This looks helpful. Now all I need is for my sunblind to break!!!
Anyway I emailed AGA, gave them the model 2006 750Li and I get a reply "All I would need is for you to look at the track and connect and see if it matches the one we advertize". Can't really tell since it broke in half, so, yours fit no problem right? I want to order this right away, just want to be sure... Thanks for your help... |
Also be mindful that the slider will only fit into the sunblind assembly in one direction. So be sure to fit the slider into the blind assembly first before attaching it to the control arm with the rivets. Good luck. Sent from my Desire HD
nice info
I'm looking into making about 4 sets at work I'll let you see the results my rear shade broke 2 days ago ***57608; now I'm on a mission to re create them so I don't spend the $120 haha
![]() 04 745i 22s 6" lips l.e.d halos,parking lights,license lights.smoked headlights& tails. Acs roof spoiler,fiberglass box 2 10's. Split personality exhaust |
Hats off to All German Auto. I think they are entitled to make some money on this repair kit, just as money is made on the coolant weep hole fix.
I'm not looking to make money at all just help if I can and have spares for me
Since u not looking to make any money, would u ship me some when u make it. Mine is broke n will use ur help. Thx. Pm me when is done thx again
Mine came in on Friday from All German Auto. Very nice. I have not have time to work on it, but I will post when I do. Hopefully without competely breaking the arms while I install this
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
