Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 09-22-2011, 11:44 AM
EMC EMC is offline
Mein Auto: 2010 335d +Turbo E36 Vert
Originally Posted by Axel61 View Post
EMC are those OZ ALLEGERITAS, I'm plannig in getting them in black. for my 35d Montego Blue with Chestnut interior
OZ Ultraleggera's. 19x8.5 front and 19x10 rear. Very strong and light wheel for the price.
Old 08-14-2012, 08:55 AM
coljediv coljediv is offline
Mein Auto: 2011 335d
Modest 2011 335d Suspension Upgrade
I have a base model 2011 E90 335d (no sports package and no mods). Since everyday street handling is my main interest, I evaluated ways in which I could improve the handling of the car without doing anything too radical. I have had the car for a little over three months, and I felt that its handling was unbecoming a BMW, in that it wallowed a bit over slight elevations or depressions in the road at highway speeds, and it didn’t settle down promptly when encountering road imperfections. I didn’t particularly want to lower the car even though I think it looks a bit better when that is done, as I don’t plan to take it to the track all that much. Having said that, I didn’t rule out the idea of lowering it an inch or so.
So, I evaluated changing the springs, the struts/shocks, the sway bars, the wheel size, and the tires. I went against my basic instinct of not lowering it, and evaluated the H&R spring upgrade (1.3 in in front and 1.2 in in the rear lowering) and some Bilstein or Koni strut/shocks (which I have done in the past with my old 2002 and a Jetta I had. But couldn’t find for the 335d anything that looked like a matching set, and I didn’t have the money or interest in experimenting. Then I looked at the Bilstein B16 coilover kit, which seemed to have promise, but got a bit nervous from reading the blogs. Again, I didn’t want to spend money and be disappointed.
So, I backed off and yesterday I had installed just some Bilstein B6 Sports struts/shocks, nothing else. There is a noticeable difference. When the springs are energized, these dampers quickly “dampen” the oscillations the way I think they should, without making it really any harsher than the run-flats already make it. It is slightly more twitchy on less than perfect pavement, but nothing that I dislike and it seems to give me better road feel. At Speed in Hanover also gave me a nice alignment. So I am quite pleased with the results of what I have done so far.
Next steps? Well, I thought I might upgrade the rear sway bar a tad by installing the sway bar from the Sports Package. I bought it and haven’t received it yet. But to my chagrin and embarrassment I discovered after that fact that the dealer sold me a sway bar that is no different than what I have installed. Seems that the rear sway bar for the base model and the M Sports Suspension option is the same, although the front sway bar is the same. So now I am starting to research the H&R rear sway bar, which is 20mm vice the OEM 13mm. I am a bit concerned that I will change the car from being an understeerer (which is OK for an amateur like me) to an oversteerer (which would require me to enhance my skills more than is probably possible). Still pondering this. Don’t know whether I will mess with the springs or not.
After they wear down I will eventually replace the run-flats with something else.
Constructive comments are welcome.
Old 08-14-2012, 11:29 AM
Axel61's Avatar
Axel61 Axel61 is online now
Mein Auto: 335d
Well I decided to use the KONI FSDs and left the NON sport springs on, and the car handles 100% better than before. One problem is i have to realign the LCI's since they are now downwards and I believe because of the height increase of almost half inc or more.
RENNtech Flash, WAGNER IC,Koni FSDs,Execuhitch,VMR710 19"
Old 08-14-2012, 03:00 PM
GreekboyD GreekboyD is online now
Mein Auto: 2009 BMW 335d
I first went with the intention to get KW V2s. However, the place I went with messed up the order, they had V3s on site and were offering me them at V2 prices so it was a no brainer.
Old 08-15-2012, 03:54 AM
Height Before and After
I forgot to measure height before and after. I had intended to do that when thinking about the Bilstein B15 coilovers, but now I can only guess. The rear seems about the same. Visually the front looks slightly higher, just looking at the gap between the top of of the tire and the fender.
Am wondering what the effect would be now of putting on the H&R 20mm rear sway bar. Intent is to reduce the understeer, but would that be overdoing it?
Old 08-15-2012, 03:57 AM
Snipe656 Snipe656 is offline
Mein Auto: 2009 335d
Is this common with BMW vehicles for the ride height to increase so much via jus changing the dampners? Only time I have seen that happen is when the old ones were so worn that the vehicle was sagging. But that obviously would not be the case when replacing something so new.
--Aaron
Old 08-16-2012, 10:05 AM
Axel61's Avatar
Mein Auto: 335d
@ Snipe I will go to the dealer to have the LCI aligned, BASTARDS might try to trick **** me into the warranty BS LOL!!! To be honest to you the car feels great, my friend who has a 330i loved the smooth ride, he was impressed!!
Old 08-16-2012, 11:29 AM
I care more to know if the ride height increase is normal.
--Aaron
Old 08-22-2012, 08:59 AM
Axel61's Avatar
Mein Auto: 335d
I believe so there is a height increase, mines sure went up but I dont care considering our roads down here
HTML code is Off
