License plate bulb wiring help
The left side wiring stopped working. The right side bulb and socket work there, but not on the left side. Any suggestions?
Yes. Remove the bottom finisher inside the trunk lid, and poke around in there.
Did you replace the bulb?
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
I replaced the bulb. The left side new bulb and housing work on the right side but not on the left side.
Classic problem. - E39 (1997 - 2003) > Light bulb above the license plate needs replacement Classic solution: - E39 Electrical Problems Traced to Trunk Lid Harness Wire Chafing (DIY Diagnostic) Quote:
Thank you Blu
Blu you were right I did a quick fix for now and put electrical tape and those two broken cables
Snap a picture of the broken (or repaired) wires. Make the picture as close to the wires as you can focus so that we can better tell what it looks like. We're trying to determine exactly WHY these wires are breaking and that's why we want the photos. Thanks. |
i agree with what others think...perhaps gray and blue cars had a factory defect at some point down the assembly line and the cables are not long enough which causes them to fold and brake. In the past I have had luck with electrical tape holding together broken wires like this even if pulled (i added electrical tape to the slack i reconnected without soldering and it is working for now) . Im hoping the electrical tape absorbs most of the fold affect for a long time, next time i will add more cable length.
The "blue bmw loom of death" strikes again!
![]() Quote:
But, the equally valid assumption they are being bent to death may apply. BTW, I consider it a success that we can predict exactly which wires are broken simply based on the symptoms observed! |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
