Is this a good deal for a 540i motor? - Bimmerfest - BMW Forums
Old 08-04-2011, 06:19 PM
my2275bug my2275bug is offline
Mein Auto: 98' 540i 56'vw bug 01'CBR
Hello everyone. I'll try to keep this short. I have a 98' 540i with 250,000 miles. This motor was running good n strong, til I blew a head gasket. Or even worse, warped a head. My plan was to fix this motor. But out of curiosity, I stopped at a BMW wrecking yard down my street. I asked about a complete motor for my 540i. They said they had a couple. $1200 for motor. And if I wanted them to install it would be +$500 for labor. They also offered 3months warranty on motor and labor. Would this be a better way to go?? Thanks in advance....
Old 08-04-2011, 06:26 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
How many miles on the engines? Sounds a lot cheaper than rebuilding yours.
However, I would hesitate having a junk yard swap my engine.
Old 08-04-2011, 09:15 PM
Hello edjack..... The motor I saw said 98' 103k miles on tag. This junk yard is also a repair shop for BMW n mbz. And they alway seem to be busy with customer cars. Or I can save $500 and install it myself.... Just being lazy
Old 08-04-2011, 10:33 PM
bmw_n00b13's Avatar
Freude am Fahren
Mein Auto: 99 528iA
There's computer aspects to this too. While they may do it right, junkyards aren't known for telling the WHOLE truth. OTOH having them do it is easier and if they do it right (I'd have a Gt1 plugged in soon after) it will be worth it.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 08-04-2011, 11:00 PM
I've never taken an engine anywhere near 250K miles so, I'm in unfamiliar territory here. Most blown head gasket threads appear to be the result of overheating (e.g., see these threads (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30)).
Was that the case with this engine?
Or, do they (at high mileage) ... just spontaneously blow the head gasket (presumably due to long term normal wear and tear)?
Old 08-05-2011, 10:39 AM
my2275bug,
Before they install the engine, consider having them replace the CCV valve, the following gaskets: valve cover, upper timing chain covers (intake manifold?); water pump, t'stat, engine mounts.
While they have the upper timing case open, ask them to inspect what they can see of the chain guides.
Can anyone add to this list?
$500 sounds like a bargain. I wouldn't DIY to save that small amount.
Old 08-05-2011, 02:04 PM
Originally Posted by edjack View Post
engine ... CCV ... valve cover, upper timing chain covers (intake manifold?); water pump, t'stat, engine mounts... inspect ... chain guides.
I'll add this to the tandem jobs thread:
- Typical tandem DIY repair jobs combined while you're already there (1)
Originally Posted by bluebee
- If you're replacing the engine, consider also replacing
- Necessary suspension components
- Motor and transmission mounts
- CCV & hoses
- Cooling system components
- Belt drive system components
- Clutch (if warranted)
- ?What else?
Originally Posted by Fudman
If you are replacing the CCV, you should also replace the hoses. Just blow the dipstick tube clean.
If you are replacing the radiator and water pump, you should also do the expansion tank, fan clutch, various pulleys and belts.
If you are redoing the front suspension, you should consider replacing the struts, thrust arms, sway bar links and tie rods.
If you're replacing the engine, replace your Vanos seals.
In the early days, it cost me $450 just to get a battery replaced at Stevenscreek BMW in San Jose!
Old 08-05-2011, 03:34 PM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
i would buy it swap it and rebuild the one that you blew from fresh and be ready to swap it back
15486372<-----
Old 08-05-2011, 03:58 PM
franka franka is offline
Mein Auto: E39 540i Sport
Sounds like a good deal with a warranty.
Mileage will not wear out a head gasket. Overheating is why head gaskets go. That is assuming the engine had never had the head(s) off since new.
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 08-06-2011, 08:41 AM
Thanks for clarifying that as I was wondering if the head gasket just pops at some mileage (he's at 250K so that's a LOT!).
If overheating was the reason, then these links may help the OP:
- Summary advice to provide users who suspect a major engine repair due to overheating (1) & how to test an engine for blown head gasket, cracked heads, a warped block, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & a well researched reusable response to a particular user with a blown engine (1) & what questions to ask when severe heating-related damage is initially suspected (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what E39 engine swaps are most recommended (1) (2) (3) & how to lift & remove the engine (1) & where to obtain a new or rebuilt replacement short block or long block (1) (2) & why the E39 engines are so prone to heat-related damage in the first place (1)
Old 08-06-2011, 11:13 AM
I've got 230k+ miles and I'm running syn 20w50 in this Dallas heat and its running very, very well.
I was having to add a little oil between changes when running 0w30 or 0w40 but not now.
Frank
540/6
