Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 08-01-2011, 07:25 PM
Ataglance Ataglance is offline
Mein Auto: 1988 528
sagging differentialk/drive axle
My differential mount is broken. The bolt is gone, probably broken out because of rust.
When it broke it caused the rear end to vibrate and make a noise that sounds not good. Now the drive axle and differential are sagging and actually resting on the exhaust.
I was wondering if the mount is replaced and the differential/drive axle reconnected would the vibration stop or is there likely lasting damage as a result of the broken mount?
Also what size is the bolt in the mount?
Any experience is greatly appreciated. Thanks in advance.
Old 08-01-2011, 08:11 PM
catso's Avatar
catso catso is offline
catso
Go to Realoem.com and look up the appropriate diagram. It will have a corresponding parts list that will tell you what size bolt you need. Your questions about vibration will be answered when you replace the differential mount. Take a close look at the other rear problem areas: subframe mounts, lateral links (dogbones), trailing arm bushings, rear shocks and shock mounts. Anything made of rubber deteriorates over time and can contribute to vibrations and noise.
![/I][/FONT]
HTML code is Off
