Old 08-06-2011, 06:40 AM
dalejewell dalejewell is offline
Mein Auto: 2010 BMW 328I coupe
Brake fluid change at BMW dealer
Had my car into the BMW dealer for oil change: They told me my car needs brake fluid change at NO charge, ok dhange the fluid:
They said they did change the brake fluid:
My question is: Does the dealer flush the brake fluid or just change the fluid at the master cylinder?
I could find no signs that the fluid was changed at the calipers or at the master cylinder.
Does anyone know how the dealer changes the brake fluid?
Old 08-06-2011, 06:47 AM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
I don't know the answer, but it appears to me that the reason why this oil needs service so often (every 2years) might be because there is only a portion of it that is changed. It is often referred as a brake oil flush instead brake oil replacement.
Old 08-06-2011, 07:05 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Per the TIS, they will bleed in standard fashion, starting with the farthest caliper from the master cylinder, then the ones closest. Most dealers use pressure bleeders attached to the master cylinder now, but some still use the two-man method.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 08-06-2011, 12:21 PM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
With labor rates being what they are? Not in the S.F. Bay Area. I wonder if the techs in the Bay Area even know how to do the 2-man bleed procedure.
Old 08-06-2011, 12:39 PM
thekurgan's Avatar
Bad Lieutenant
Yeah, I hear you there, but if you really want a good pedal feel, the two-man effort is worth it, and a rubber mallet on the brake caliper doesn't hurt either while bleeding
Ilse
Bruna
BMWCCA #453648
Old 08-06-2011, 12:59 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
A proper bleed REQUIRES a pressure bleeder; it is not possible to bleed the ABS/DSC module without one (and the BMW computer of course).
I have done the two-man with my car; works fine, but there is definitely no abs bleeding possible without the pressure on the master cylinder, even with a BMW computer cycling the ABS.
The pressure bleeder model still requires the pedal to be pushed a few times.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 08-06-2011, 01:04 PM
Easy Rhino Easy Rhino is offline
Mein Auto: 2006 Corvette Coupe
No need to have a two-person bleed - that's the old school manual method.
All decent shops use vacuum or pressure bleeders, which is a one-man operation.
They will flush out all of the brake fluid if done correctly, starting with emptying and refilling the master cylinder reservior with fresh fluid then purging through the individual lines to the slave cylinders at each wheel, until the fluid runs clear, using s presurized fitting at the reservior cap, or using the vacuum system (not as easy).
This is a maintenance item you don't want to ignore.
Old 08-06-2011, 01:31 PM
thekurgan's Avatar
Bad Lieutenant
Yes, ABS is a PITA for the DIY'r.
I've been using Mike's DIY guides for years now.
http://www.madrussian.net/m3/diy_brake_bleed.shtml
Ilse
Bruna
BMWCCA #453648
Old 08-06-2011, 06:34 PM
Lufthansa Lufthansa is offline
Mein Auto: 2010 E92; '07Lexus GS350
Just out of curiosity, because I also have a '10 328 Coupe - why did they change the brake fluid so soon? My understanding is it's done every 2 years.
Old 08-07-2011, 07:16 AM
bballfreak bballfreak is offline
Mein Auto: 2009 335d
It is hard to really know that it has been done?
unless one checks the color of the brake fluid coming out of the
caliper. It is quite easy to fool folks by just sucking out the
old darker fluid out of the reservoir and filling it
with new fluid.
BTW, does 2009 335d use DOT4 or DOT5?
Old 08-08-2011, 08:25 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
One thing to remember about the 2 year brake flush, the two years starts to run from the date of manufacture, not the inservice date like the "free" oil changes do. As such you should be able to get 2 free brake fluid flushes under the 4 year "free" service plan. N4S
