The X5 SAV Forum
Old 08-06-2011, 09:45 PM
jsatbimmerfest jsatbimmerfest is offline
Jubba
Mein Auto: 2003 X5 3.0L automatic
Unhappy AC fuse keeps popping
Hello everyone
I am having a problem with my 2003 X5 (E53) AC system
The fuse keeps poping whenever I replace it. I have changed 4 fuse over the pase month. BMW did a diag. and did not see an issue with the IHKA but did mention shorts inpanel. The fuse that keeps popping is 48 (in the glove compartment)
Anyome know what my issue could be?
Old 08-06-2011, 10:47 PM
petener999's Avatar
petener999 petener999 is offline
Mein Auto: 750i, x5 4.6is, E46 M3
Disconnect your battery for a few minutes and reconnect, that should do the trick.
Old 08-09-2011, 09:23 AM
X546IS_GUY X546IS_GUY is offline
Mein Auto: 2002 X5 4.6IS
A/C Fuse 48
That fuse is a 7.5 A fuse I believe. If I recall, I believe that one powers the A/C compressor clutch. I don't like to diagnose over the internet/phone but I have a feeling that your compressor clutch is failing. Couple things I would do (some not proper by the book) but if you were to unplug the A/C compressor clutch connector, BLACK with GREY tracer stripe. Put a new fuse in and power up the Control Module and set to A/C. If the fuse does not blow, you're probably into a compressor clutch.....
If it is intermittent, it could be the clutch shorting-to-ground or an exposed wire between the controller and compressor clutch. I've attached a Wiring Diagram.
I hope this helps!!! Good-Luck....
Old 08-09-2011, 02:43 PM
edsx5 edsx5 is offline
Mein Auto: 2003 bmw-x5 4.4i
Sounds to me like your compressor clutch is fine. check the pressure switch at the dryer cannister. The clutch is in series with the pressure switch. If the pressure switch senses enough freon pressure,it engages the clutch. The clutch is driven by the belt and is a coil winding which magnetizes and runs the compressor. If there is a short in the clutch, there will be no cooling,Period. If there is a short with the pressure switch the switch is grounding to the chasis negative shorting out the fuse. Bypass the switch with a jumper wire then work the compressor a couple of times .If the fuse holds, then the switch needs to be replaced. If this does'nt work, there is a high resistance short in the A/C system. Check to see if the compressor is not getting stuck with the engine and A/C on. You should hear a loud squeaking noise if the belt is slipping. If it is, have a tech reclaim some of the freon and charge a cannister of oil and freon gas. Hopefully this should lubricate the compressor .Dont try to charge the system yourself. Have a tech check the pressure in the system. Good luck.
Old 08-11-2011, 10:04 AM
Jubba
Thanks for your comments.
I did have the battery changed about 3 weeks ago by the dealer. What a hit! The AC fuse started popping round about that time. I will approach these 3 suggestions one at a time to see if it helps. The issue is intermittent so very hard to predict. at times it will go for a week and at other times it would go for a day or will pop right away. It sounds like some sort of shorts and I am a bit nervous about messing with this beast. I am mechanically inclined but not having a good handle of the advanced computer in these vehicles is causing me to be cautious.
Old 08-13-2011, 08:02 AM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Not sure if this is the case for your problem but:
I remember reading (either here or on xoutpost) that the little fan that draws air to the cabin sensor can pop a fuse when it get dirty. You might want to try a search to see if you can find the relevant post on either board. All it took was a quick blow out using canned air to cure the problem.
Old 08-16-2011, 12:48 PM
Jubba
Thanks for this. I will be focusing my attention on it over the weekend. I hope something will solve the problem. I will be sure to update.
Old 02-20-2012, 08:40 PM
OneEyedMan OneEyedMan is offline
Mein Auto: X5
Hi
Just wondering if you had solved the problem. I have exactly the same thing with my E53 X5
Old 05-09-2012, 03:59 PM
escondidogerman escondidogerman is offline
Mein Auto: 540i
Found the fix
Check this link out and let me know if it helps.
Old 09-01-2013, 02:21 PM
Jubba
Hello guys... I just can not believe that I did not respond to what corrected my problem. Not good.
Well I did resolve the problem. I removed the module and cleaned out the fan as was suggested by @Zulu95. You should see the stuff that was clogging the fan!
I have not had a problem since.
Old 06-05-2015, 08:10 AM
vangustia vangustia is offline
Mein Auto: X5 3.0
Fan module
Where is the ac compressor fan module? This is happening to my x5 right now and I want to clean it to see if it works before I spend $$$ on buying a new ac compressor. Thanks!
Old 07-28-2015, 09:32 PM
dan emmabel dan emmabel is offline
Mein Auto: BMW
faulty RPM signal
please my toyota highlander v6 2008 4wd,is having a particular problem. there's an oil holes that I have changed twice. this oil holes boost twice now,
when I used a diagnosis machine its shows me :12; faulty RPM signal (no RPM,NE and crankshaft position signal transmitted to ECU after started for 2 second)
1.ckp and cmp
2.distribution fault
3.start circuit open or short
4.module fault
please I need a technical support.
