The X5 SAV Forum
Old 10-31-2016, 07:49 AM
The Enforcer The Enforcer is offline
Mein Auto: BMW X5 2005 e53
Steering Wheel Vibration
Hi All
I need some advice re BMW X5 2005 e53.
For the past 2 months Heavy vibration in steering wheel.
Had rear tyres changed and all 4 wheels balanced and wheel alignment done.
Still no joy. :-(
It vibrates extremely as soon as I hit 56mph - 70mph. There is still a vibration beyond this.
It then vibrates hard if I hit the brakes at any speed.
My local garage is useless.
BMW garage will rip me off hence why I have come on here to seek advice from you people who will know (I Hope) what I'm going through.
Thank you.
Old 10-31-2016, 08:51 AM
Fifty150hs Fifty150hs is offline
Mein Auto: SF Bay Area
Originally Posted by The Enforcer View Post
Hi All
Still no joy. :-(
Thank you.
Sounds like you need new thrust arms and control arms. How many miles on your X5?
Old 10-31-2016, 09:35 AM
It's got 160000.
Just had new arms put on few months back.
Old 10-31-2016, 02:51 PM
It's got 160000.
Have you replaced any other suspension parts? Ball joints, torsion bar end links or tie rods? Bad tie rods could be the culprit.
Old 11-01-2016, 07:40 AM
thrillcat thrillcat is offline
Mein Auto: 2005 BMW X5 4.8is
I had a similar issue - specifically the very heavy vibration under braking - and it ended up being the CV axle. Swapped those out and the vibration went away. About 8 months later I had a very light vibration start to come back. At that point I swapped out upper and lower control arms and ball joints and I've had zero vibration since.
2008 X5 3.0si Alpine White
Old 11-01-2016, 10:41 AM
Thank you for advice.
Old 11-09-2016, 01:57 PM
Shawnv Shawnv is offline
Mein Auto: E38 & X5
Same issue fixed with a new inner n outer tie rod passenger side and then took her in for an alignment...that part will be covered in a different post. Took me 15 minutes and the part was 80. From my local napa shop. I have a lifetime alignment program. (A necessity)...
