Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Car Audio & Electronics Forum
Hi-Fi upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here!
Old 04-25-2004, 03:42 PM
Nick325xiT 5spd's Avatar
Nick325xiT 5spd Nick325xiT 5spd is offline
Send a message via ICQ to Nick325xiT 5spd Send a message via AIM to Nick325xiT 5spd Send a message via Yahoo to Nick325xiT 5spd
Mein Auto: M3 & 323i/999 KP
Reasonable 5/6 channel amp?
Unfortunately, the HK system in my M3 really sucks ass.
Really, really, really sucks ass. It's a good deal worse than the standard system in my old wagon.
Anyhow, to start this process, I'd like to find myself a 5 or 6 channel amp that meets a couple of requirements: It MUST cost less than $400, and it must accept balanced inputs. I would like to avoid using a line converter of any sort.
Suggestions for a four channel amp along with a one or two channel amp that fit within this price and compatibility requirement would also be accepted.
Beyond that, I want good, clean sound. It doesn't have to be the best in the world. I can get that at home. But I can only tolerate so much ****ed up mid-bass.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black
1999 323i KP/GTS2 Alpinweiß
1990 325is Brilliantrot/Tan
1989 325is S50B30US Alpinweiß/Black
1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
Old 04-25-2004, 04:04 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
Hmm, you might be best off with a used amp. Most that directly take balanced inputs (newer a/d/s, xtant, etc.) tend to be costly, especially in multichannel. Although mine is one model too old to take balanced, I got a great deal on eBay for a a/d/s P840. I'm finally getting back around to finishing the system, and it should sound pretty good when its done.
Old 04-25-2004, 04:47 PM
CWolfey CWolfey is offline
Mein Auto: 2004 325CiC
You can go with a Kenwood amp, they are clean, have the power you want and are probably in that price range, and have the high level in you are looking for too.
I have a Mono Kenwood bass amp running at 1.3 ohms to 3-8" 4 ohm woofers and never heats up or shuts down, pretty happy with it.
I have also installed many other Kenwood amps and have had great results.
So check them out and see if they meet your needs.
Kenwood
Old 04-25-2004, 05:10 PM
Dr. Phil's Avatar
Dr. Phil Dr. Phil is offline
The Original Dr. Phil
Send a message via AIM to Dr. Phil
Mein Auto: 2012 135 coupe
Hmmmm.......should have saved teh $675 j/k
For $400 look at the Kenwood, if you want to do mid 500 you could get jl 500/4 amp. What else are you going to add other then an amp We need to chat about this more
2012 135 Coupe Alpine/Black; M Sport, Premium 2, 7 sp/dual clutch, HK, Sirius, Apps, Nav, Heated Seats
