E46 (1999 - 2006)
Old 08-14-2011, 05:51 AM
eds325i eds325i is offline
Mein Auto: 2002 BMW 325i
Exclamation A/C Blower Fan Not Working ?
Hey Guys I need some help. The blower fan in my A/C ( or heater) does not blow. On the display it says its on. The Auto feature trys to adjust the blower fan speed to the proper speed but nothing happens! Basically everything works but the blower. Also this is a intermitten problem. One day it will work fine and one day it wont? I will check the fuse-if there is one. But other than that what else could it be? 2002 325i Automatic 79,000 miles
Old 08-14-2011, 09:57 AM
jburns's Avatar
jburns jburns is offline
Mein Auto: 2007 BMW 328i Coupe
Final Stage Unit/Resistor. Mine does the same thing, but works more than it doesn't, so I haven't changed mine yet either. But search on here, there are hundreds of threads/DIYs on it. Starless has the best DIY with pics. Not too big a deal......pricewise, ....but you need to be Gumby to get to it! LOL
Old 08-14-2011, 10:03 AM
thanx, will look into into
Old 08-14-2011, 11:30 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
If it is the FSU, a quick /FSU in the bestlinks nets the following ...
- What is the canonical thread on the BMW E39 FSU/FSR/Blower Motor Resistor (1) and what is the right brand FSR to purchase (1) (2) when your interior heating & air conditioning HVAC/IHKA blower motor goes haywire (1) (2) (3) (4) (5) (6) (7) (8) & how to repair your own final stage resistor including an autopsy & wiring diagram schematic (1) (2) and why a bad final stage unit will cause the battery to drain overnight (1) (2) (3) & how to isolate and replace the E39 blower motor (1) (2) (3) (4) (5) & how not to replace the FSU (1)
Note: These were written for the E39 FSU; however, the solutions appear to apply equally well to the E46 FSU ...
Old 08-14-2011, 12:54 PM
Thanx Blue, Will tear into it this weekend
Old 08-15-2011, 05:39 AM
Svobodax Svobodax is offline
Mein Auto: 325i
This looks like a nightmare. How did it go?
Old 08-15-2011, 06:27 AM
Still didn't order part yet but saw it for $66 shipped will order and install this weekend. Wish me Luck
Old 08-15-2011, 02:52 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
Final stage resistor
Get the BEHR unit from www.autohausaz.com for $62 shipped and use my DIY video
Old 08-15-2011, 03:25 PM
I Appreciate the help Jake, Couldn't do it without everyones help
Old 08-16-2011, 04:14 AM
PRS330d PRS330d is offline
Mein Auto: 2001 330d Touring
Smile
Hey guys, I'm a new BMW e46 owner from the UK, had a few glitches with my car (2001 330d Tourer), and have managed to solve all of them from reading posts on this forum (and a few others..) I had a similar problem with the A/C when the fan would either blow at full speed or not at all, when I googled it looked like I was gonna have to change the Final Stage Resistor, but one of the last posts I read on another forum said that BMW recommended removing fuse number 50 (40 amp in my case, but believe some are 30 amp in other cars), which kills the power to the FSR and resets it. Did this a couple of days ago and hey presto, every works fine now, saved me removing the FSR and changing it. Maybe you could try the same and see how you get on?
Old 08-16-2011, 06:26 AM
Makes sense. I will definately try it
Old 08-29-2011, 07:10 PM
icbinb icbinb is offline
Mein Auto: 01 BMW 325i
Any success yet?
Old 08-30-2011, 11:33 AM
I have not replaced DFU yet, the last time my blower stopped working, I Pulled over and removed fuse # 50 (while car was still running) waited a minute and replaced. To see if DFU would reset as some have suggested. It has been about 3 weeks and have not had any issues yet. So just waitin to see if it holds up so I can replace before winter if needed.
Old 11-08-2011, 10:55 AM
santhukarukayil santhukarukayil is offline
Mein Auto: bmw 528i
Thankzzzzzzzzzzzzzzzzzzzzzzzzzzzz lotttttttttttttttttttttttttttttttttttttttttttttttt tttttttttttttttttt
Old 11-08-2011, 02:15 PM
LGATL LGATL is offline
Mein Auto: 2014 535d
Had the same problem two weeks ago. Was the Final Stage Resistor just as everyone has stated. Quick fix by my independent.
Old 11-08-2011, 06:33 PM
After trying the pulling out fuse trick to " reset " DFU. I have not had any issues
Old 05-28-2013, 01:45 PM
zeeshan zeeshan is offline
Mein Auto: bmw e-46
hello guys I have same problem my blower is not working some times it start blowing every thing is working else today I changed my fsu resistor but still the same I tried the fuse thing but it does not effect at all what should I do kindly suggest I m not gona waste my money on the mechanics more please advice :-(
bmw e-46 2003
Old 05-28-2013, 02:08 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
know where the FSU was made? there have been reports of bad "new" ones made in China. go figure....
blower itself can go bad too, as can the climate control unit in the dash
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 05-28-2013, 05:23 PM
Mein Auto: bmw e-46
Firstly i order it on ebay some kind of usa made with life time warranty it has no pins on it i fixed it in my car it was not working so i thought its a design issue or may be its cheaper thats y its not working but then i read some of the topics they suggest to buy from bavarian auto so i order the behr made in Germany cost me around 54$ when i changed it today it does not work as well now i don't now what can i do i also check the 50 & 28 they are fine i also reset them several times but didn't work at all
Old 07-22-2013, 04:57 PM
AOE AOE is offline
Mein Auto: 99 BMW 323i
Can you tell me where the motor is located please, I have already changed the FSU, and my a/c still won't kick on. the only time I get cold air is when I'm going over 35mph. I wanted to test the motor.
Old 07-22-2013, 11:02 PM
Mein Auto: bmw e-46
Ya its same with me my car fans does not work at all but i feel some air when i drive it fast enough or when i get a car wash and its dryer turn on then i get some air any way to change the blower motor u need to open the whole dash board its not an easy task as theres a air bag inside so if u do any thing wrong it will blast like an explosive and to fix that air bag u need to replace it it will cost u a lot thats y i did not do it by my self i was not afraid but i don't have the second car and the blower motor price on eBay is 250$ almost so i got the estimate from firestone they charged me 475$ for replacement along with motor and 1 year warranty so i chose that option and it took two complete days to them to change the blower so u can now think they are professionals and they took 2 days and for us how much time it will. Take we never know so i will suggest u go take a quote from different places and go for the cheeper one and i can confirm u that its ur motor fault
Old 07-22-2013, 11:52 PM
Dougly503 Dougly503 is offline
Mein Auto: 00' 328ci
Same problem here, Thank you!
Old 07-23-2013, 04:29 AM
ahull's Avatar
You get to the blower from the engine bay. See e46 wiki link above for links to DIYs and other info. It is a little tricky but very doable.
Old 07-25-2013, 09:31 AM
Katmg Katmg is offline
Mein Auto: 525
Thanks everyone! Still trying to get at the darn fuse but at least know what I need to do
Old 09-22-2013, 11:13 AM
alex23preu alex23preu is offline
Mein Auto: bmw323i
Smile 1999 bmw 323i blower not working at all!!
Hey guys , i was having some issue with a/c blower not working at all , i replaced the final resistor for the a/c blower and now the blower is working properly .i just wanted to share with my experienced
