Old 08-16-2011, 08:40 PM
nono323 nono323 is offline
Mein Auto: 2006 650i
heater not working
so this morning i went to turn on the heater and for some odd reason it wasnt working has anyone eles had this problem ??
Old 08-16-2011, 09:58 PM
Yorgi's Avatar
Yorgi Yorgi is offline
What does "not working" mean? No air blowing? Did you have the fan speed on "auto" or did you manually spin the fan speed dial?
If you have air blowing but no heat, then it's probably just the manual air settings under iDrive > Climate. Check out page 101 & 102 of the owner's manual. Here is post with a shot of the page.
If you see a solid blue torso on the iDrive screen then the car is set to blow cold air only. Use the iDrive controller to select the square with the + and - sign then turn the iDrive dial clockwise until you get a red torso. You will now have heat. Mega BMW design fail if you ask me. I though my heating was broken until I found this setting and it is VERY poorly described in the manual.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 08-17-2011, 09:39 AM
Thank you Yorgi,
what i meant to say was no HOT air was comming out and i did what you said to do, an i agree with you on the "Mega BMW design fail " im glad they dont ask you to type in a code for the heat lol
my dads lexus ls 600HL along with most other car are so simple, climate>heat and bam hot air lol
