Old 02-07-2013, 04:12 PM
Schitzo Schitzo is offline
Mein Auto: 2000 528i
Originally Posted by doru View Post
Apparently the e53 fan & fan clutch have a re-designed fan, that holds the blades together, so the fan would not shatter as it does with the current model.
The 530 with diesel engine have a similar design AND 2 versions: for hot climate & for cold climate. The question is: does the diesel WP (which is different from the gasoline engine WP) have the same threads for the fan clutch as the gasoline WP? below is the exact diesel fan blade that does NOT shatter:
This is just a guess but I would think the thread is the same. I also think you could probably just bolt the diesel fan onto the gasoline fan clutch. I suppose the diesel fan is designed that way due to the higher NVH associated with those engines.
l Stock 2000 528i l
Old 02-07-2013, 09:02 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
That's the 1,000,000 $ question. I guess only the guys from Europe could let us know. Because if you look at the diesel WP, it's a totally different design. So I would be skeptical to think they are similar. They could be, but I am not sure.
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 02-09-2013, 11:27 AM
If you do a google search using the terms, Euro, diesel, fan, and BMW, you find some E36 people have done this swap. i.e. bolting the diesel fan to their fan clutch.
There is also another question that needs to be answered, does the diesel fan move as much air as the fan for the gasoline engines? Diesels run much cooler than their gasoline counterparts hence my question.
l Stock 2000 528i l
Old 02-09-2013, 11:32 PM
doru's Avatar
Looking in realoem, there are 2 types of diesel fans: One for cold climates and one for warm climate. I suppose the one for warm climate will move more air.
