Old 03-04-2012, 10:17 AM
DHHathaway DHHathaway is offline
Mein Auto: 2003 Z4 3.0i
I have the original Carver Amp from my 03 Z4 but the sub-woofer channels are dead (the original sub-woofers are a joke anyway - I replaced mine with JL Audio 6W3v3s and added a 300 watt amp to drive them). I'd be willing to part with the amp for a dime on the dollar plus shipping.
Old 06-27-2012, 06:29 PM
71trigirl 71trigirl is offline
Mein Auto: 2004 Z4 3.0i Roadster
DHHathaway - would you still have that amp? I am interested. Thanks.
Old 01-29-2013, 02:09 PM
ShellShock ShellShock is offline
Mein Auto: 2003 BMW Z4
Need 2003 BMW Z4 Amp
Hi all, I'm new to the forums but am also searching for the hard to find BMW Z4 Amp. Same water problems via the break light. If anyone has one or knows of a new solution please inform!
Old 09-19-2013, 05:34 AM
Cgroh360 Cgroh360 is offline
Mein Auto: Roadster z4
I also have the amp problem and need to find fix. Should I try and find stock amp or change it to an after market amp
Old 09-19-2013, 09:04 AM
I have found no fix
My brother is an electrical engineer. He has done numerous tests of the circuits and has it narrowed down but not going to be easy to fix - if at all. I'm going to opt for a new/ used factory amp for simplicity. I don't listen to hi-def anything, mostly news... so that will work for me. Problem is, I haven't found one within my budget. Guess I'll be increasing the budget!
Old 10-26-2013, 11:37 AM
Hey apologies if this is too late!
I found my replacement amp on Ebay (it was used) and ran around 500 bucks if I remember correctly.
They aren't easy to find, but be careful you get the same serial number or are sure it is the correct amp as there are a few different models.
Best of luck!
Old 09-16-2015, 08:55 AM
major smash major smash is offline
Mein Auto: Honda civic si
carver dsp amplifier
adkinskel@yahoo.com if anyone needs one . I realize this is an old post. Just seem to make sence to post here because if you search for it this post pops up the most
