Old 08-19-2011, 03:31 AM
maxo898 maxo898 is offline
Mein Auto: 1997 BMW 740il
Post 97 740iL - Navigation system screen not working
Hello i have a 1997 BMW 740il that has a navigation system in it and the screen inside doesn't turn on at all but the radio works perfectly fine but i just don't know what radio station im on and without the screen i can't adjust the equalizer like the tone bass balence station and treble.(only the speakers in the front work and the ones in the back are perfectly fine but don't work. Note: I don't want the navigation system i just want the screen to work so i can adjust things. Please advise or suggestions Thanks
Old 08-23-2011, 04:14 PM
exred92 exred92 is offline
Mein Auto: 2001 740i sport
Sound like your nav computer went south.If you have an MK2 navi you can pick one up on ebay fairly cheap.
Good luck.
Old 08-23-2011, 05:26 PM
740il
So is that the one located in the trunk where you can also insert a cd in it
Old 08-23-2011, 06:01 PM
Yes that is correct.
Old 08-26-2011, 06:33 PM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
Good luck.
Just curious - why do you think it's the Nav that's bad? Usually when they go bad, the radio will start then shut off by itself as the system realizes the Nav is not working correctly. But, then you can click the radio off & back on again & it will work again for a couple more minutes. The OP's radio stays on (from what I read).
To me, it sounds like his Nav screen is what's going/gone bad. He can hear the radio, but just can't see the screen info to tell him how to adjust the fader & stuff.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 08-26-2011, 08:39 PM
When i look in the trunk and look at the navigation system computer the 2 little orange lights work.(I really don't want the navigation i just want the screen)
How do i know if the screen is the one that's bad?
Old 08-26-2011, 09:51 PM
Thumbs down
This is the Navigation system attached.
Old 08-27-2011, 02:17 PM
This won't be much help, but the only way I know to easily test the screen is to swap in a known working one (maybe from someone that lives in your area?).
Old 02-05-2012, 05:39 AM
ozkar ozkar is offline
Mein Auto: 2001 BMW X5 3.0
Hi guys, I have a 2001 BMW X5 3.0 with the following radio/nav issue: radio works fine, only I can not see radio stations in the screen. The navigation orange light don't come ON. I have Mk3, when insert a CD come in/out without problem. Can you please help with this problem. The problem is my radio/nav or my Mk3 or the screen needs to replace???
Thank you guys for your help.
Ozkar
Old 02-05-2012, 05:08 PM
Can you please give a little more detail?
Does your Navigation work OK, and you can see the map?
If it's just the radio stations you can't see, is it the radio station displayed on the Nav screen, or is it the radio stations displayed on the Mid (under the cluster)?
Any pics of the problem would be very helpful.
Old 02-06-2012, 02:58 AM
Thank you sealbeach740, I can not see map and radio station. Mk3 ejects CD without problem.
When I push the Navigation knob, the orange light didn't come ON and the screen shows like grey color.
Thank you for your help.
Old 02-06-2012, 04:45 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
If you have TV as well as nav, switch off ignition and disconnect the nav. Now switch on for 2 mins, then off, then on again. You should now see a blue screen with all menus except the nav.
In addition, if you have upgraded to widescreen and lost the INFO and SELECT button functions, these become available again with the nav disconnected
Old 02-06-2012, 06:27 PM
If you don't have a TV module, then it sounds like your Nav computer isn't working correctly.
Does your radio go off after 2 minutes? Can you get it to go on again by turning the radio on again, but then it goes off again after 2 minutes? If so, then almost for sure it's your Nav computer in the trunk.
Old 02-11-2012, 07:26 AM
bostonchef328is bostonchef328is is offline
Mein Auto: 96 328is
I have a 96 740il the navy/tv screen comes on but what happens is there's a msg that says "bitte warten" the radio works fine but can't use screen can anyone help?
Sent from my SPH-D700 using Bimmer App
Old 02-12-2012, 05:26 PM
My radio is working fine. The navigation didn't work. When I push the Monitor button (on the radio) the orange light didn't turn ON and the screen shows like grey color. My MK3 ejects CD with no problem.
I don't know if the problem is the screen, or the MK3 or software or part of the navigation inside the radio is wrong?
Really appreciate your help peolple from bimmerfest.
Old 02-13-2012, 01:50 PM
Mein Auto: 750iL
You said you didn't want the nav, but the screen is there for the nav. If nav (or TV or both) hadn't been specified at purchase, then you wouldn't have the screen either since there would be nothing to dislpay that couldn't be shown on a basic system. Check the 2 plugs to the back of the nav are properly located; also the 2 to the monitor. If still not working and you have genuine software and map cds, then its time to replace the nav
Old 03-14-2012, 04:40 PM
jamelkhalil jamelkhalil is offline
Mein Auto: 735il
Hello
I have a problem with the word does not appear on the navigation screen showed you the date and time and then disappeared for the navigation device works and you replace it and the same word problem does not appear on the screen navigation help me BMW 740 model 1997
Old 03-07-2013, 07:59 PM
Turned out to be that the screen was bad, i went and baught another one.
Thank you all for your help
Old 07-20-2013, 12:34 PM
Jonjo Jonjo is offline
Mein Auto: 740i
Hello I don't know if I'm in the right forum ,but I have. 1995 740i. Since the tv digital change over the tv stopped working is the a easy fiix
Old 07-21-2013, 04:49 AM
Mein Auto: 750iL
Well yes, there is an easy fix, but at a price. You can buy a digital tv module that is simply a plug n play replacement for your existing. You will get all the freeview channels. You have to very careful buying these tv modules, as there a lot of versions about. The latest versions also support widescreen monitors, but that is yet another cost to change...if you can find a r/h drive version.
Example - I have not used this vendor, but ebay germany is a good place to find them.
http://www.ebay.de/itm/BMW-TV-Modul-...item3cb5d1861b
Old 07-21-2013, 05:05 AM
Mein Auto: 740i
Hi mate thanks for your reply I shall have a look on eBay is the unit in the boot and do I just plug the mod. In the back of it thanks
Old 07-21-2013, 05:09 AM
Mein Auto: 740i
My car is 740i. On a 95 plate
Old 07-22-2013, 03:45 PM
Mein Auto: 750iL
Ignition off. Remove the l/h boot trim. Remove the Nav with radio style hooks and unplug (if you have upgraded to a MK 3 version, then make sure the nav unit indicator light has gone off first) ; then the trim to the NAV; then unscrew 2 plastic fasteners to right of nav. Ease trim free at the top. If it feels fixed at the bottom, there may be 2 plastic rivets holding it to the chassis rail best removed with a panel tool, screwdriver if you have to. With the trim off, TV/video module is the big silver one on your left, held in with one screw with 2 lever connectors on top plus 2 small square silver ones which just pull off. With practice, 10 minutes all done. Oh, and those 2 plastic screws? Well contact adhesive the bits that fell off to the back of the trim and gently replace the screws.
Old 07-23-2013, 01:38 AM
Mein Auto: 740i
Hi chrisn7 thanks for info ill have a look for a cheaper one than 699 then try to sort best regards john
Old 08-05-2013, 11:40 AM
jaxmom7709 jaxmom7709 is offline
Mein Auto: 97' 740 il
97 740il cd error
Radio, display, tape, as well as controls all work properly when a cd is inserted into 6 disk changer an error message is displayed on the radio. Also, equalizer can be adjusted but all my interior speakers sound blown and pop even if the volume isn't too high. Any thoughts?
HTML code is Off
