E36 (1991 - 1999)
Old 08-19-2011, 02:23 PM
loljdmlolE36 loljdmlolE36 is offline
Mein Auto: 1993 E36 325i
93 325i Eletrical problems.
My car doesnt want to start . It was runing until i parked and everything eletrical stayed on in the car . I tryed jump starting it and it wants to turn over but doesnt it turned on with starting fluid but quickly dies out. I changed the ignition and still. Any suggestions?
Old 08-19-2011, 02:57 PM
tchavera tchavera is offline
Mein Auto: 323is
you're letting it charge up a little when you jump start? have you tried recharging the battery? just to completely eliminate that option
Old 08-19-2011, 03:25 PM
Yeah i tried to with a v8 but your right i havnt taken it for a recharge.
Old 08-19-2011, 03:29 PM
Dino1394's Avatar
Dino1394 Dino1394 is online now
bimmerfest Supporting Member
Mein Auto: 04 330xi
I think the battery is junk now but try recharging it first as said above
Sent from my HTC HD2 using Bimmer
Old 08-19-2011, 04:51 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
If it started with starting fluid, then you have a no fuel issue. Check out the fuel pump and fuel pump relay. Those may be your issue
RIP Ben "Jever" Doebele, we wont forget you
Hi, I'm Chad. Talk to me or GFY
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates, so many more cool things!
1993 Chevy K3500 CUMMINS 6BT 5 speed with 19.5" commercial grade wheels. Pulling 15k pounds going 75mph up a 7% grade... cake
Old 08-19-2011, 06:24 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
That's a fuel problem, not ignition. If it started on starter fluid but then dies, the ignition is working, but you're getting no fuel through the injectors.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 08-21-2011, 05:47 PM
Hyperchargedvol Hyperchargedvol is offline
Mein Auto: 1993 325i
What Horn said.
