E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
95 325i 5 speed 4,000 rpm driving 60 mph in 5th?
I just bought a 1995 325i convertible, and it is quite nice, but I have not driven a BMW before, so I am not sure if this is normal. In 5th gear, I am running about 4,000 rpm going 60 mph. Is this normal? Am I going to get horrible gas mileage on the interstate? Thanks everyone!
i have the same thing yes bad gas... cause i have a modified diff so its super fast accell haha
I like the colour No Bias. 1995 325is 5spd |
You probably have a 3.73 or higher diff ratio. Swapping out to 2.93 or 3.23 will help your milage, but will give slower accel
![]() RIP Ben "Jever" Doebele, we wont forget you Hi, I'm Chad. Talk to me or GFY ![]() 1997 328iS... HR coilovers, Brembo F40 calipers, camber plates, so many more cool things! 1993 Chevy K3500 CUMMINS 6BT 5 speed with 19.5" commercial grade wheels. Pulling 15k pounds going 75mph up a 7% grade... cake
How would I find out what my differential is?
If you're really turning 4000rpm at 60mph in 5th, you most likely have a 4.44 diff from a 318 auto. The original ratio is supposed to be 3.15.
Theres a tag on the diff. You have to read the numbers on it. I dunno how to decipher off the top of my head, but thats what googles for
You don't have the original differential in your car. At 60mph, it should be between 2.5 to 3k.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
I briefly got under there tonight and found the tag, but I couldn't read it. It looked original and rusty in areas like it should be stock. I will check it out more tomorrow. Any advice on cleaning it so I can actually read it?
Its probably an OEM diff, like out of an auto 318 as mentioned, so it may have seen rust before it was ever on your car. Wire brush should help clean up the rust. Otherwise carefully take it off and try and read it under better light
3:15 . 8991 Ratio
I got under there today, and the differential tag said 315 8991. So, it is the correct differential. I checked out the rpm's again today, and checked my speed on the GPS to make sure it was accurate. At 60 it is turning about 4,000 rpm, and at 70 it is turning about 4,650 rpm. The clutch is not slipping. After inspecting a bunch of stuff today, could any of this be the problem:? The rubber flange or bushing from the transmission to the drive shaft has a rip starting in it (I am sure this isn't the issue), the intake hose, just after it goes into the car, and it looks like it goes down toward the alternator?, is busted and missing a good chunk of it, a cable that runs to some contraption at the front drivers side of the car with a sensor (says VDO 12V) has the plastic cover mostly gone and the metal is exposed, and I pulled the plugs to check them out and I found a little dab of oil where the plug goes, and when I pulled the plugs out they were covered in oil and mostly black, with a little bit of gray. I am also going to post all of this stuff and introduce myself in the proper area for new people. Thanks in advance for the ideas.
How many RPMs in first gear going 20? None of that would cause high RPMs.
I think your tach is screwed up or the tag on the diff is wrong. No way it's turning 4k at 60 with a 3.15. You should be doing 98 mph at 4000rpm in high gear, and about 112 at 4650.
Correction: I thought 5th was an overdrive like 0.93. It isn't. It's 1:1 1995 325i BMW 5 speeds have 4.2; 2.49; 1.66, 1.24 and 1.00 gearing. Guesstimating you have 205-60-15 or equivalent OD tires, your speed at 4000 rpm with a 3.15 differential would be 90 mph. At 4650 you should be going about 105. The diff is either tagged wrong or your tach is way off. You should be turning about 2650 at 60 mph. Data for this was calculated here: http://www.car-videos.net/tools/spee...B1=Recalculate You have to manually plug in the transmission gear ratios and the differential ratio, plus your tire size.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! Last edited by hornhospital; 08-20-2011 at 04:41 PM. |
More Info
I went out for another drive, didn't run the air con or anything. When the car was warm, it was idling around 1,600 rpm, and sometimes would be close to 2,000. The car did the rev up and down a little at idle after I got home after I lugged it up the driveway, after it was warm. Tire size is 205/60-15.
1st gear @ 20 - 5,500 rpm 2nd gear @ 20 - 3,200 rpm 3rd gear @ 20 - 2,100 rpm 4th gear @ 20 - 1,400 rpm 4th gear @ 40 - 3,000 rpm 5th gear @ 40 - 2,400 rpm 5th gear @ 50 - 3,200 rpm Oh, and the 5,500 rpm, pretty much felt like high rpm's. Thanks for sticking with me guys.... This out of all of the stuff I listed on the other thread is the most concerning, because it just doesn't make since! |
I say you have a incorrectly labeled diff. To see if the tach is right you'll need to hit the rev limiter, which is 6500. If you are on the rev limiter (and you'll know because it wont rev up any more) and the tach is at 6500 or so, you have a highly geared diff. You'd have to plug in the known diff ratios into Kens calculator to figure out what diff you really have
I'm thinking the tach is incorrect. I doubt you could be idling at 2k rpm without a very serious ICV problem or vacuum leak.
Try the redline test like chad said.
-CJ
Well, if this is the case, than that kinda sucks. I really don't want to run at high rpm's on the highway all of the time. I guess I may need to look into a swap? Is a really low geared differential desirable to anyone? I guess I will go out and the to blow up my car
, and hit the rev limiter soon. Keep the thoughts coming - thanks.
Hitting the rev limiter isn't going to blow up your car. Just do it while the car is warm, and don't hold it there for more than a few seconds.
-CJ
I'm pretty sure the tach will READ way past red line when it finally hits the limiter (but it will still be only ~6500). Are you sure the IC hasn't been swapped, maybe one from a 1.8/1.9liter 4 cylinder? Don't know if that would make a difference or not, just throwin it out there.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
So if my tach shows that I idle at 1,600 rpm's, then would it make sense that it is the tach? How could the tach get messed up? Is there a way to check if the tach is functioning properly?
Idling at 1.6k isn't a sure sign that your tach is bad. Testing the redline, as previously mentioned, would be a sure way to do it, though.
-CJ
If the tach is wrong, then would yo be able to test the lowest rpm then engine can still pull at.
My -92 non-vanos (which is a notoriously poor low-rpm performer) can accelerate gently in 2nd gear from ~500 rpm without starting to buck. If your tach is way off and you try to do the same, your indicated 500rpm would be something like 300 real. This low rpm would cause the engine to nearly stall. |
instrument cluster
The mention about the instrument cluster being replaced has me worried a bit. I am going to attach a picture of my IC, see if it looks normal. It was born 11/94. I have not driven other BMW's so I don't know. I did notice that I don't have the mpg gauge.
I'm wondering if this is not an older type cluster with the 140mph limit.
You can access some info in the cluster described in this webpage: http://www.bimmerinfo.com/E36_OBC_tricks.htm Try 'test sequence 02' to see if it reports a 4-cylinder or 6-cylinder engine. |
If you are truly idling at 1600 rpms you should be able to hear that clearly since that's double normal idle. We're not talking a subtle difference here.
If it turns out your tach is correct, one other thought is that your car has had an automatic to 5 speed swap. If that was done and you still have the diff that matches up with the auto tranny your highway rpms are about right.
A 325 auto had a 3.91 diff and that's too low a ratio for the 4600rpm at 70mph. I'm thinking of such a diff swap for my 325 manual and it would give ~3900 rpm.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
