Old 08-21-2011, 07:23 PM
smmerz56 smmerz56 is offline
Mein Auto: 1984 BMW 318i
Engine compression low
Hello. I recently purchased an 84 318i. It's got some problems, but it is running ok with some idle problems. I felt like I should of been getting better gas mileage, so I decided to give it a compression test before I started putting $ into it. The 2nd and the 4th cylinder are hitting around 60 psi. While the 1st and 3rd are around 90 psi. Has anyone had any experience with this? Is it going to need a new engine or maybe some kind of adjustment? Any help would be much appreciated.
Thanks,
Sean
Old 08-22-2011, 06:12 PM
Killjoy's Avatar
Killjoy Killjoy is offline
OEM Hoe....
Send a message via AIM to Killjoy
Mein Auto: 1999 M3, 2002 tii
You may need a valve adjustment, as I do not think e30's had hydraulic lifters. But regardless, you are in the wrong subforum for this problem. Go to the e30 forum and see if you have better luck with a solution there.
Originally Posted by Cmy_bimmer View Post
Oh your talking about THAT hole.. yeah thats an inspection hole
Old 08-23-2011, 01:44 AM
Andrew*Debbie's Avatar
Andrew*Debbie Andrew*Debbie is offline
resU deretsigeR
Mein Auto: Leaf Tekna
This post is in the wrong forum. Hopefully a moderator will move it.
Yeah the M10 engine has solid lifters. There is a DIY writeup here --> http://www.bmw2002faq.com/content/view/21/33/ It is for the M10 in a 2002 but early 318i should be the same. . .
60psi is very low. Engine is probably worn out. Valve adjustment is certainly worth a try.
