Old 03-27-2004, 11:05 PM
Randy Forbes's Avatar
Investigative Tinkerer
Playing in the trunk...
I'm not sure if I'll even be able to use this once the repair has been made by BMW. I'm still waiting to see which way the fix will go but I'm not sitting on my thumbs in the meantime.
I mocked up the reinforcement for the inside of the trunk this evening. I used 10 gauge sheet metal but in reality, 14ga. or maybe even 16ga. would probably be adequate. While I didn't weigh the finished piece(s) yet, I expect them to be in the 5 to 7 Lb. range.
There are worse things in life than adding little weight directly over the rear axle in a nose heavy car.
I wasn't able to get the top stamped from one piece like I had wanted; no room to do back to back bends that close with the dies they had. Instead, I used 1/2 x 1/2 x 1/8 angle and ran it through the mill to get the required heights to match the embossments in the trunk floor (bevels and all) and fabricated it from nine (9) pieces.
The angle pieces that fit over the longitudinal rails were cut in half from my original planning. This would still allow gradual deformation in the event of a rear shunt, once the cavity deforms to the point of the axle anyway.
This is still under construction so it's not pretty!
Still have to finalize a design for the underside, should have the two eared cover and OEM brackets early next week (surprised when they didn't arrive Thursday, probably not that many people ordering things like that).
ID:	28051   Click image for larger version
ID:	28052   Click image for larger version
ID:	28053   Click image for larger version
ID:	28054   Click image for larger version
Randy Forbes
2001///M Rdstr Steel Gray
Old 03-27-2004, 11:25 PM
I forgot to mention...
If I get this all smoothed out tomorrow (meaning Sunday), I'll put the battery, cables, trays, floor, et all back in to see what still fits and what doesn't.
I didn't remove the factory studs that were in the way, I just milled or drilled to get around them for the time being. The (cheap) plastic nuts won't grip the studs as they are now, I would either thread the plate or put studs on it in the same locations.
BTW, I am not advocating this mod in any way. It's just something that I'm doing to satisfy my own curiosity.
Old 03-27-2004, 11:47 PM
TeamM3's Avatar
TeamM3 TeamM3 is offline
Living on the redline
Mein Auto: a BMW killer
damn, the extremes some people will go to just to avoid buying a Z4
Yesterday's history, tomorrow's a mystery, but today is a gift; that's why it's called the present
Old 03-28-2004, 04:29 AM
Dennis33's Avatar
Dennis33 Dennis33 is offline
BMW Z4 Coupe
Mein Auto: 2007 Z4 Coupe 3.0si
Talking When a Z4 performs as well as.....
a ///M Coupe/Roadster, then maybe there will be more Z4 owners.
BMW Z4 Coupe 3.0si (2007)
- Jet Black exterior
- Red leather interior
- 6-speed
- Sports Mode
- Sports Suspension
- BBS CH 18" wheels (8.5" & 10.0")
- ///M Sport Seats
Old 03-28-2004, 05:33 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Looks like your welder showed up.
How do you like it?
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 03-28-2004, 08:20 AM
How do you like it?
Just like old times...
I also put O2 sensor ports in the Healey's collectors (for an l.e.d. mixture indicator) and got the mufflers fitted up so I can set the carbs without killing the neighbors.
Old 03-28-2004, 04:23 PM
I checked the fit of some of the trunk fixtures and was pleased to see that very little needs to be done to make this work and be invisible to the untrained eye.
Specific to the S-54:
the battery cover portion that goes over the cables
tool tray needs to be trimmed
fasteners for the battery cable guards
The rest looks okay...
Haven't had the chance to test fit the pice to the S-52 yet.
ID:	28070   Click image for larger version
ID:	28071   Click image for larger version
Old 03-28-2004, 05:57 PM
elfhearse's Avatar
elfhearse elfhearse is offline
Mein Auto: 00Z3MC,10e91-ZMP,14e8928i
The final step is to weld the pieces to the floor?
I was looking around for 1/8" plate strips myself to add as a stiffener but you're way ahead of me.
If it fits, are you considering selling a "kit" to weld on the trunk floor & diff ear??
(probably a strong demand for 300+ Coupe/roadster owners)
Old 03-28-2004, 06:37 PM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
late comment
I haven't spent as much time looking at this as many of you have. but...
I thought a plate down below, between the existing bracket which the diff ear bolts to, running straight up thru the floor to a bar would work.
Or assuming the existing bracket below is strong enough as is, a bolt with a big washer straight up thru the existing bracket then up thru the floor to a bar, would also work.
Randy, sounds like you have your car with BMW for a warranty fix?
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit 1, touch lane change
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 03-28-2004, 06:54 PM
LmtdSlip's Avatar
LmtdSlip LmtdSlip is offline
Do the interns get Glocks
Send a message via AIM to LmtdSlip
Mein Auto: 325iC
Why not trim the reinforcing plate rather than the OEM plastic bits?
Photobucket
Old 03-28-2004, 09:06 PM
MGRMLN's Avatar
MGRMLN MGRMLN is offline
Mein Auto: Z3 and Z4 M Coupes
Hey randy,
This looks like very nice work.
Will you be selling this as a kit?
If so, I'm interested.
Minsoo
Old 03-28-2004, 09:48 PM
///M Rakete's Avatar
///M Rakete ///M Rakete is offline
Rocket Scientist
Mein Auto: 2010 M3 and 2011 135i
Originally Posted by MGRMLN
Hey randy,
Minsoo
Ditto on the nice work and the kit.
2010 BMW M3 Coupe M-DCT w/Tech-EDC, BMW M Performance Exhaust, BPM Stage I Tune, Space Gray / Fox Red Extended, and a Trunk Monkey known as "Der Stig",
plus the daily driver...
2011 BMW 135i M Sport DCT, w/BMW Performance Power Kit, Exhaust, and Brake Rotors, Space Gray / Coral Red, known as "Stiggie" with an outlaw F20 "M135i" badge.
Old 03-28-2004, 09:53 PM
The reinforcing plate is made the width it is to sit directly on top of the xmbr flanges that are underneath the trunkfloor. Once welded in place (plug welds through holes in the trunk floor NOT just to it) it will tie the lower xmbr to the plate in the trunk.
Hey randy,
Minsoo
Thanks. I doubt it, too much production variance. I'd be willing to do it on a custom basis though. Also, I'd need someone with a Coupe to come by so I could measure and take into account the different brkts that you guys have holding up the trunk floor.
Randy, sounds like you have your car with BMW for a warranty fix?.
You're reading my mind Bob. I still have the underside to mock up, maybe have something ready to look at by next week. I'm thinking about a vertical membrane. Be pretty hard to bend 3-some inches of steel edgewise...
BMW hasn't given me the answer yet, but I'm lead to believe it will be positive...
Correct. Well, not so much to the floor as THROUGH the floor.
Ten gauge is .120" (1/8" is .125").
I'm motivated by two (2) cars with structural problems
To many issues of fit and finish right now, have to wait and see how this plays out with BMW too. Stay tuned for more information
Randy Forbes
Old 03-29-2004, 05:28 AM
BobC BobC is offline
Looking for a project car
Mein Auto: '99 M Coupe, '95 318ti
What part of Ohio do you live in? I'd be willing to drive over if it's not to far. Let me know.
Bob C.
Secretary - Michiana Chapter, BMW CCA
'95 318ti - my daily driver
'99 M Coupe - my toy
'99 740iL - wife's daily driver
'76 2002 - wife's toy
'07 Chevy Silverado 2500HD - for taking the Coupe to the track
"If you find yourself in a fair fight your tactics suck" - unknown
Old 03-29-2004, 06:03 AM
Thanks for the tip. I'm in Toledo...
Old 03-29-2004, 07:34 AM
yetiboy yetiboy is offline
Mein Auto: '00 M Coupe
On my list of life's "To-do's" - Visit Pro Football Hall of Fame in Canton and see a OSU-GoBLUE showdown in the Big House in Ann Arbor. Maybe kill three birds with one stone...it's only a 2400 mile drive from sunny Nocal
MSH
Old 03-29-2004, 08:25 AM
LmtdSlip's Avatar
Mein Auto: 325iC
I realize how and why...my point was that perhaps you could make the cut outs in the reinforcement piece before welding them in that way the battery cover and the tool tray would drop right in without have to trim the OEM pieces. I think this would be more appealing to someone buying it as a kit.
Just a thought...but nice work you did there regardless.
Photobucket
Old 03-29-2004, 01:30 PM
DannO's Avatar
DannO DannO is offline
Mein Auto: //M Coupes
Last year sweating as you installed short-shifters will be nothing compared to this year at homecoming with the welder.
Old 03-29-2004, 03:59 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
Should I figure out how to bring my 4500W 'portable' generator with me? Hmm, if disassembled, it might fit in the trunk... oh, right, not a good idea until _after_ the trunk has been fixed.
Daniel
2002 M roadster
Old 03-29-2004, 04:07 PM
Pinecone's Avatar
M Mad
I have a 6500 watt generator, and another welder.
Hard to bring in the Roadster.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 03-29-2004, 08:02 PM
I'd be up for that road trip. It would be a good excuse to go to Cabela's. Let me know.
Bob C.
Old 03-30-2004, 05:39 AM
elfhearse's Avatar
ha.... second cup of coffee and alot of bizzaro things come to mind for HC this year. Everyone can show up with their welding hoods, "Got Crack?" t-shirts... bad idea, Bubba's Welding is the newest vendor in the parking lot..I'll stop now.
Old 03-30-2004, 03:37 PM
DannO's Avatar
HAHAHA - Got Crack - that's great!
I've already started thinking about this year's t-shirt... that's a contender, along with //M-Bark's "COUPE de'tat" suggestion regarding Coupes boycotting the new hotel and going back to the old one or choosing another one all-together.
COUPE de'tat seems like the perfect fit for us and our misfit cars.
Old 03-30-2004, 04:24 PM
work goes on...
Bob,
I said you were reading my mind...
Made it through another segment of the project today. It's also a stopping point as I can't go any farther without actually modifying my car. Not a good idea while waiting on replacement trunkfloor(s) from BMW.
All along, it has been my intent to have a vertical membrane to connect the existing lower xmbr to the new reinforcement plate.
What is the point of reinforcing the top if the lower xmbr can still break away?!
The OEM differential brkt is made of (just under) 12 ga. steel (mount=.076"/12 ga=.081"). This could be fortified any number of ways without getting complicated.
I'll deal with the two ear issues in another post...
ID:	28215   Click image for larger version
ID:	28216   Click image for larger version
ID:	28217   Click image for larger version
ID:	28218   Click image for larger version
Old 03-30-2004, 05:03 PM
You've got to really want to do this...
Here's a few shots of the E-36 M differential cover.
Capacity looks to be the same, baffles are different and almost a lack of cooling fins (this could be remedied).
Height and offset of ears are different than the single ear Z3///M cover. Mount isolators are also smaller/more rigid and appear as though the bracket is in a single plane (as opposed to the Z3///M that wraps around to two planes).
It's already been done, and it would lend itself well to my proposed reinforced trunkfloor/xmbr modification.
I would suggest that something like the Ireland Engineering sub-frame bushes be utilized to limit travel considering the firmer isolators on the differential cover mounting lugs.
ID:	28225   Click image for larger version
ID:	28226   Click image for larger version
ID:	28227   Click image for larger version
ID:	28228   Click image for larger version
