E36 (1991 - 1999)
Old 08-22-2011, 09:41 AM
bimmer765's Avatar
bimmer765 bimmer765 is offline
Mein Auto: 325i
aux fan high speed relay
I was looking at my fuse panel and it shows the high speed relay for the fan, is there anyway to test this? When we had the 100 degree heat here in IL I don't think I ever heard it hit the high speed, just low.
Sent from my SCH-I500 using Bimmer
Old 08-22-2011, 10:19 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yes, you can test it by removing the temp sensor plug on the top of the radiator and jumping the terminals. It has three terminals - connect a wire to the middle terminal, and then connect that wire to each of the outer terminals separately. You will then know if both your low and high speed relays are working. The key must be in the number 2 position.
Additional details in the troubleshooting portion of this DIY guide:
http://www.dvatp.com/bmw/diy/aux_fan/
1998 BMW 328is
1966 Pontiac GTO
Old 08-24-2011, 03:12 PM
bimmer765's Avatar
Mein Auto: 325i
I switched my a/c compressor and high speed auxiliary fan relays and now for some reason they both work now.
