E60 (2004 - 2010)
Old 08-23-2011, 09:01 PM
silverstar_12 silverstar_12 is offline
Mein Auto: BMW 525XI
Transmission sealing sleeve leak
Hi, I have a 2006 525XI with 53K miles. Had it in the at the local dealer for an oil change and dealer mentioned transmission sealing sleeve is leaking...wondering if anyone else had this experience. Thanks.
Old 08-23-2011, 10:27 PM
rctmthouse rctmthouse is offline
Mein Auto: 550i
when you said sleeve, are you referring to the gasket? If that's what you're referring to, I too have that problem. It's a DIY job. Should cost you between 150 to 300 on parts depending on what type of liquid gold you want to pour into your tranny.
Old 08-23-2011, 10:29 PM
Mein Auto: 550i
but if you're referring to the mechatronix sleeve then it is still a diy job. Should cost approximately the same as the price I posted up there since the sleeve itself only cost around $ 20. It is recommended that you change the fluid and pan at the same time.
GL
Old 08-24-2011, 08:04 PM
Hi Thanks for th reply. It is the mechatronix seal that is leaking very slightly. Dealer wanted 1100$ for the job and the part cost is $20. Need to figure a way to do it myself....
Old 08-24-2011, 08:50 PM
Mein Auto: 550i
Read the following threads, it will definitely help you feel more comfortable with doing this yourself.
http://forums.5series.net/topic/8812...-drain-refill/
http://forums.5series.net/topic/1121...%2Bmechatronic
http://www.thectsc.com/index.php?p=p...=187&parent=43
http://www.thectsc.com/index.php?p=p...id=3&parent=10 <==== the part you need is around $ 15.00 only
Please note, it's entirely up to you to decide what kind of fluid you want to you use for your tranny or how you want to proceed. It varies in price but the cheapest one would be the Mercon SP and it's a compatible fluid. Lots of Jags owners and some BMW owners are currently using it right now, myself included, no problem so far. You can also reuse your fluid and filter since it's only 50K+ miles.
If money is an issue, just order the sleeve, pan gasket, and one or 2 litters of the ZF fluid and you're good to go.
Be sure to watch the youtube clip near the end of the 1st thread to get an idea of what needs to be done in removing the pan and and read the instruction on how to replace the sleeve in thread 2 from CTSC. There are other threads on how to replace the sleeve but I didn't bookmark it.
Good luck!!!
Old 08-29-2011, 02:56 PM
Thanks much!
Old 03-14-2012, 11:51 AM
dembones64 dembones64 is offline
Mein Auto: '06 530i
transmission sleeve
have an 2006 530i with the same problem?
Old 03-14-2012, 12:45 PM
repoman75 repoman75 is offline
Mein Auto: 2008 535 xi
Had the same problem, ran me $1000 at the dealer.
Old 12-11-2012, 06:58 AM
jfreeman jfreeman is offline
Mein Auto: 5 Series 2007
Mine was $720.00
Old 12-11-2012, 07:11 AM
235301 235301 is offline
Mein Auto: 06 525xi Monaco Blue
Same problem here, 2006 525xi with 60k miles. Had it fixed recently at my independent for $600. Independent told me it is a very, very common problem on this model; so much so the local dealer is stocking the kits used to do the repair. That gives me concern we'll be doing this repair on a regular basis.
Old 12-11-2012, 07:15 AM
I'm not worried. Maybe mine will last another 86,000 miles.
Old 12-11-2012, 07:30 AM
WJGreer's Avatar
WJGreer WJGreer is offline
Mein Auto: '05 545i
I'm pretty sure this happens to every E60 at about that mileage level. It can cause all sorts of odd transmission behavior when the fluid gets a little low, most notably the "surging" problem that has gotten so much airtime on this board. Certainly something to fix. I was able to get mine done under CPO.
-Will
2005 545i Sport | 2001 X5 3.0 Sport (Retired)
Old 12-11-2012, 10:18 AM
I am including an interesting video although it does not apply directly to the sleeve seal. It really shows the Mecktronic part replacement. Before the repair, my car was shifting a little higher in the RPMs (about 3,500). Now it is back to around 3,000 where it belongs. I will attempt to attach a photo of my car. BTW. The sales tax on my repair was $93.31 in (Columbus, Ohio). That's still better than the tax on a new 5 Series. The total bill that day was $1,475.64. That included engine oil change, brake fluid change, TPM sensor ($230.00), micro-filter ($153.58) and trans sleeve seal ($683.00 even). Here in Columbus, Ohio, the total labor was $889.42. The parts were $467.92. Repair costs on a Ford or Chevy would run about the same. Anyway, if you can't afford to run a beemer, you should buy a New Nissan Leaf or a Ford or something. BMW owners should never complain.
Old 12-11-2012, 03:46 PM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
^ that's not mechatronic sleeve replacement video.
Old 12-11-2012, 07:58 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
My advice is to replace the sleeve if you have a car from before 2009 model year. The newer seals are sturdier and likely to last for the life of the car. It's a one time deal and you likely won't have it happen again. The part costs under $20, labor is $3-400 plus consider replacing the transmission pan if you have high mileage, ie over 75k.
Styling: M5 body kit, M5 trunk spoiler, LED Angel Eyes, HID fogs, LED side markers, Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Zapco Z8 DSP, Zapco Z-150.6 amp, iDock on dash
Performance: JB4/G5 ISO flashed on Cobb, Meth Injection, AR Downpipes, ER FMIC and Charge Pipe, DCI, Walbro LPFP, RB turbos. H&R Sport springs/Koni FSD shocks.
Old 12-11-2012, 08:01 PM
The work has already been done. I guess that you didn't see the original post. It was $683.00 even. I'm not complaining. Thanks for the tip about the oil pan.
