Old 08-24-2011, 02:01 PM
jcalhoun jcalhoun is offline
Mein Auto: 650i convertible
Acceleration lag, 650i convertible, standard shift
Lag is most noted around 2500 RPM's, in 2nd or 3rd gear while attempting to accelerate quickly. BMW service has cleaned the injectors, replace fuel, checked mass air sensor, valvetronics test per TSE, update DME per measures plan, check energy diagnosis.
I previouly owned a 2007, 335i convertible, with standard shift. I was very pleased with the way that engine responded. Just a little small for long distance travel. Since this is my first 6 serries, I wonder if my expectations for the V8 are inflated.
Has anyone had the same or similar problem? Any solutions?
Old 08-24-2011, 08:30 PM
Bk650's Avatar
Bk650 Bk650 is offline
Nerdy G
Send a message via AIM to Bk650
Mein Auto: CLS 550
i think they designed it that way on purpose..
Greg A
650i on 22's Asanti, mtec v3 angel eyes, Custom exhaust...(retired)
2000 GS300 heavily modded(retired) gone but never forgotten
1998 LS400 Daily driver (retired)
2005 Range Rover HSE (family car) Lost in Divorce
Old 08-24-2011, 09:32 PM
Zeke77 Zeke77 is offline
Think Solar
Mein Auto: 2008 X3; 2007 650i conv
I don't seem to have that issue with the same configuration vehicle. Can you give some further detail on the lag you are feeling? I mean, some people are more sensitive than others...That said, I've hit it pretty hard accelerating out of second to merge onto an awkward freeway onramp near my house, and I've never noticed a lag. Does the engine flutter for you or does it simply feel like you are getting very low torque?
The only other time I've heard of a similar issue (and this is a long shot...) was in a neighbor's 645. His was an issue with the air flow sensor, but it sounds like you've got that covered. In that case, however, he only got about two or three symptomatic lags before the whole thing failed and had to be replaced.
MY2007 650 conv | Stratus Gray | Black Pearl | HUD | Night Vision | Sat | Logic 7 | RT Traffic | Cold Weather | 6-speed Euro Delivery completed 9/15/06
MY2008 X3 3.0si |Monaco Blue| Sand | Sport | Prem | NAV | Auto | Euro Delivery 9/21/07
2004 X5 4.4i (retired)
Old 08-25-2011, 05:04 AM
Question More on 650 acceleration lag
The lag is most apparent when I hit it hard at aound 2500 RPMs, mostly in second gear.
There is always a lag between pedal push and acceleration, but not the hesitation described above. It feels like the fuel system is loading-up.
I am driving a similar equipped car today and hope to be able to make a comparison. Service department has been considerate and communicated with BMW engineers. I hope this is not the way all 650 standards shifts respond.
Old 08-25-2011, 05:33 AM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2014 BMW ///M6 vert
mine doesn't have this issue - good idea with the loaner, which will hopefully perform as expected. good luck with the trouble-shooting and hope they can find a fix.
Regards, Greg
'14 M6 vert, san marino blue on amaro brown full merino leather, drivers' assistance, exec package, B&O sound system, CCB package, akra exhaust, tint, windscreen, etc.
'07 650i vert, beige/jet black, sports & cold weather pkgs, comfort access, etc.
'11 Acura MDX Advance with Entertainment pkg for wife - no mod's '04 Acura TSX (daughter) and '12 VW GTI - Autobahn (son)
Old 10-02-2012, 11:59 AM
bcorwin bcorwin is offline
Mein Auto: 650i Convertible
Did you ever resolve the hesitation issue?
I have a similar problem on my 2006 6sp. The rpm will occasionally drop 500 rpm under hard acceleration somewhere in the 2800-3800 range and then catch up again. It is like the engine stops for second. I see no codes on my Peake meter. And when I took it to the dealer he could not make it happen. Intermittent problems suck!
