Ordering new key.
I'm thinking to order this key
http://www.ioffer.com/buy/uncut-us-v...ang93-10572734 Anybody bought a key from there?? |
This key is not like the early ones you can just lift the chip out and change it over. It is attached to a circuit board. |
First, you really should consider adding some car information to either a permanent signataure or in the area where car info can be typed in on the upper right of your messages. That way you can receive better information from those answering your questions. For instance, we don't know if this is even the correct key for your car...many new owners who need the old style key...think they can upgrade to the new style key...and if this is the case...all of our suggestions and post are for nothing...since one must stay with the same type of key the car came with unless you want to do a Frankenstein key which requires surgery and other things to make it work.
WARNING! There is so much incorrect information (or glossed over info) on their site that if you did NOT catch it...you need to read the DIY/FAQ threads on this forum that explains how EWS/FZV/DWA work and how all 3 systems are integrated into the remote keys. For instance, the BMW dealer does NOT cut keys, nor do they program the EWS chip...they order it from BMW NA (and the keys come with the EWS transponder already assigned the ISN (individual serial number) that is specific to your car's VIN. The dealerhsip only programs the FZV/DWA (keyless entry & alarm siren system) which you could do yourself with any comparable BMW key in less than 1 minute with the instructions that have been posted here on this forum many times (should be in the FAQ/DIY threads). You're on your way to possibly spending money for a key that is not going to give you the final outcome you were hoping for.
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 08-24-2011 at 04:45 PM. |
It's bothersome when folks post Ebay links sans screenshots (they die so the thread will have less value in the future).
Here, for the record, is a screenshot of the link: In addition, for the OP, doing a /key F3 in the bestlinks nets this, among others: - Diamond key functions (1) & the truth about the BMW diamond key transponder (1) and proper initializing (1) (2) and the truth about the 10-key limit to programming your own keys at home (1) & opening, charging, recoding, & battery replacement (1) of the new-style diamond key (1) (2) (3) (4) (5) (6) & converting the old-style 1996-2000 "square" key to a diamond key (1) & how to replace the rubber key pads in the old style keys (1) (2) & what to do if your key is locked inside your car (1) & a description of the various types of BMW "Remote", "Illuminated", "Spare/Wallet", & "Valet/Service" keys (1) (2). |
Dang!!! Help me guys
Last night I lost my key in Walmart and left my car there. Should I bring my car to the dealership in order to program it or I can just buy new key?? Cuz the Walmart is too far away from my house(40miles away). Quick reply plz |
No...don't tow the car to the dealership...it will be a waste of money because they will still need to order a new key from BMW NA.
The only thing towing to the dealership will do is provide some sense of safety that if someone found your key at Walmart...they couldn't search the parking lot for your car. But as you've posted...the remote isn't working so they'd have to physically insert the key into the door lock cylinder to find out if the key works. More than likely they won't do that...they'll just press the remote button looking for your car (which won't work). See the other thread you started about losing your key in Walmart's parking lot. I gave a list of the keys w/part nbrs & prices etc. that can help you get this sorted out. This time, buy TWO keys...you should have a back-up/spare/emergency key...and you can get the plastic key, illuminated key, or spare key for not much money compared to the more expensive remote key.
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
If I had found the key, and, if I had wanted a spare parts bimmer in my garage, I'd wait till Walmart closed ... and in the parking lot ... would be all the spare parts I could use!
I don't know about your part of the country...but here...most Walmarts are open 24 hours...plus they video the parking lot. They also allow people in trailers & motor homes to park in the outer lot overnight...or if needing to stop and rest etc. Only caveat is that they are restricted from running generators etc (can't run a small campsite on their parking lot)...but you can stop, shop, rest, eat etc using the stuff on the inside of your motor home/trailer.
God bless Sam Walton & family.
I did order new key in this morning and wating. The dealership charged me about 250 thou. |
Ok.. I am coming back here cause I am confused.. To provide back ground, last Friday, went to get in my 00 528i and the key wouldn't unlock the doors remotely, so I thought well maybe the battery.. got in the car and wouldn't start.. gigged the steering wheel and got it to start.. so I thought well it must be the battery, so I read somewhere on here that you can simply replace the battery and then reprogram the key and all is good..
SO I bought batteries, sat there for 20 mins and could not jar loose the key.. I am thinking damn this thing is superglued together.. I think come back on here to review the instructions to make sure I was doing it right and then realized that perhaps my key battery can't be replaced and I have to buy a new one at $160-$180... My question is is that true or is there a way to open the damn thing and replace the battery.. Here is a picture of my key.. any suggestions, recommendations, etc.. |
why bother just go to dealer and get right one
Did you follow this DIY write up? Yes, it is sealed with epoxy as your diamond key is charged by induction at the ignition switch so the battery is soldered to the circuit board. http://www.bimmerfest.com/forums/sho...d.php?t=315311 Last edited by dvsgene; 08-26-2011 at 09:28 AM. |
Just bought my son a 2002 530i dsc and brake/abs light are off when I start the car, then after driving for awhile they both come on? The dealer who sold us the car says it's because the car hasn't been driven in a couple of months and the indicator lights will go off eventually. My mechanic says they tried to clear the codes and they came right back on and the abs parts are $960 or $2750!? (not including labor) just wondering if anyone has experience with this and advice on how I might be able to resolve this issue the most economically?
Suggest in the future you start a new thread with such a question as it has NOTHING to do with ordering a new key and can easily get buried here. You can start here for your ABS issue. Could be as simple as a bad ABS sensor (one of two on driver front hub or passenger side rear hub) or a more serious ABS module issue. http://www.bimmerfest.com/forums/sho...d.php?t=541000 In the future, you might want to bookmark this list of DIY/issues: http://www.bimmerfest.com/forums/sho...8&postcount=38 Last edited by dvsgene; 08-26-2011 at 09:44 AM. |
my apologies, first time here, thank you for your pointing me in the right direction.
Well I got the back end of the key open but stopped cause I felt like I was breaking it.. but will try again! Is there a cheap way to buy another key?
So, there was no 'security' in the bimmer being hidden in the parking lot. The real security is that very few people would drive off in someone else's car simply because they found the key to it. Great. Please let us know what happens. I first read that as "250 thousand"! What a difference a 'gh' makes! Quote:
My suggestion: - Click on the appropriate thread in those links and ask your question there. - Not only will that make more sense ... - But it will add to the value of that thread for anyone else looking for how to open their key Thanks for understanding. Quote:
Huh? My neighbor's cat spit up a fur ball today; but I wouldn't ask questions about it in this thread. If you have ABS/BRAKE/DSC issues (and, we all do as it's one of the most common ailments of the E39), simply go to the bestlinks and do a thread search for ABS. One of the first links you'll find about the trifecta is here: - E39 ABS DIY Isn't that actually already answered in the posts in this thread? Here's what I suggest you do:
Then post the results. At the very least, you'll have found your answer; at the very best, people will hone your answer (and others will benefit). It's all about adding value. |
Blue, I would never expect you to say something like that ,lol.
My question: If I DID have a dead battery in my key, what WOULD work and what would NOT work? |
...here it is again...an FYI for those who didn't know...
The remote keys (old & new) contains THREE features that are each distinct yet function in concert:
Transponders & Transmitters: they are not the same. ![]() EWS uses a transponder inside the key (old style) and soldered to the IC board (new style)...and a transponder receives as well as sends data. Again, the EWS system is self powered...a 125 KHz AM signal is sent from the EWS control module to the Ring Antenna, which then induces power to the EWS transponder inside the key which sends back its ISN...with the end result being self powered communication between all the EWS components..allowing the car to start. No power from the key is required. FBZV & DWA uses a transmitter inside the key...a transmitter is sending info/data...in this case, info/data is sent from the key to the aerial in the rear window which then sends that signal to the diversity antenna module/receiver located in the left C-pillar. From there the data is sent to the GM over the communication BUS system (to unlock the car and to turn off the alarm siren). This transmission requires the battery inside the key to transmit that data to the car. ![]()
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 08-28-2011 at 07:54 AM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
