Old 08-25-2011, 10:20 AM
PEIZ3 PEIZ3 is offline
Mein Auto: 1999 z3 2.8
Z3 99 2.8 Idle / Power Issues
Back looking for help with this persistant problem...
Rough idle at cold start...spitter / sputter & no throttle response. Restart car a few times and issue clears up. Once on the road, throttle response is poor with much hesitation on the top end (drop a gear and the car will take off as it should) and, after cruising along at highway speed, all power is lost & no throttle response (car will not stall out) period. Pull over, turn off car and restart immeditely, everything returns to normal and the process begins again.
Codes are indictating misfires & O2 sensors.
I have replaced / performed the following...
Precat O2 sensors...fuel injectors...intake manifold rubbers...crankcase vent valve and hoses...fuel filter...rebuilt the dual vanos...cleaned the throttle body...cleaned the MAF x 2...new plugs.
Costs are climbing without any changes...greatly appreciate any assistance offered.
Old 10-10-2011, 09:47 AM
Still hoping someone out there can help with this...last advice was to replace the CCV valve and associated hoses...did this and still no improvement.
Old 10-10-2011, 10:30 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
Is the ses light on now ? When is the last time new spark plugs installed ?
Old 10-10-2011, 10:37 AM
Sorry I see you installed a fresh set of plugs.
Old 10-10-2011, 02:54 PM
Check engine light still on...
Old 10-10-2011, 04:29 PM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 98 540i, 03 X5
Fuel Pressure Regulator been changed?
Old 10-10-2011, 09:27 PM
tohbi tohbi is offline
Mein Auto: z3 '97 atlanta blue 2.8
from a purely amateur mechanic perspective, seems it could be a computer problem, or am i just showing my ignorance?
Old 10-11-2011, 02:52 AM
Are you still getting the same codes you got before the 02 sensor install ? For a misfire it seems it could be a bad plug or a bad ignition coil. My car has 6 coils. They do go bad. What about the after cat 02 sensors. I just replaced all 4 of mine.
Old 10-11-2011, 06:35 AM
otoh, i had the same codes on my ford v6 and it turned out to be a bad fuel injector. this after changing 02 sensors and coil.
but the way the car runs well sometimes and bad others could mean a problem in the "brain."
Old 10-11-2011, 06:44 PM
Thanks for responding folks...
coils were checked and found to be good...
codes still read misfire...
FPR has not been replaced...(about the only thing)
