Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 08-25-2011, 02:26 PM
burgesat burgesat is offline
Mein Auto: 1984 533i
New owner of 1984 533i
Hi all, I am a first time BMW owner. I bought a 1984 533i off cl for $1000. It seems to be in very good running condition. I bought it from the son of the original owner (his dad who passed away). I even have the original sticker. The car has 149XXX on it. Everything works on the car except the windshield wiper fluid sprayers. I haven't tried to fix them yet, I was hoping for suggestions. The only other problem the car has seems to be with the breaks. When I get up to speed and then apply the breaks the car shakes and the "break lining" light comes on. I'm not sure what to do about it.
Old 08-25-2011, 02:38 PM
here is a pic of the car
pic of car
Old 08-25-2011, 03:18 PM
catso's Avatar
catso catso is offline
catso
Brakes are pretty easy to work on and parts shouldn't be very expensive. The shaking could be from worn suspension components, particularly control arm bushings, but start with the brakes first. Get yourself a good repair manual. The Bentley 5-Series E28 service manual is the best.
![/I][/FONT]
Old 09-07-2011, 09:49 AM
I'll keep updating the work I am doing to my new toy. I put new rims on so I didn't have to mess with the TRX tires. The tires that were on the car when I bought it had dry rot and no tread left. I also replaced the badges, which really helped to bring the car back to life.
Old 09-07-2011, 10:27 AM
I had to put spacers on because the displacement on the wheels I bought was different. so there are 20mm spacers all the way around.
ID:	292031   Click image for larger version
ID:	292032   Click image for larger version
ID:	292033   Click image for larger version
in the close up of the wheel you can see the spacer
Old 09-07-2011, 12:37 PM
catso's Avatar
catso
Looking good.
![/I][/FONT]
Old 09-09-2011, 02:52 PM
I had a day Off work and decided to give my side mirrors a face lift. I also did some other trim pieces and took a trip to the junk yard!
I sanded the mirrors with 2000 grit and then used oem trim paint from dupli-color
ID:	292391   Click image for larger version
ID:	292392   Click image for larger version
ID:	292394   Click image for larger version
Old 09-09-2011, 03:02 PM
tales from the junk yard
I snagged an instrument cluster from a 88 535i. My cluster does not have fully functioning gauges; the tach is stuck at 2000rpm whether on or off, the gas mileage works only when it wants to and my odometer stopped working. I am hoping to snatch some parts from the junk yard find to make mine whole. When I took mine out to compare it is different. I have a 84 533i, so are they interchangeable? is it possible to swap out the tach part and put it in my cluster? has anyone attempted this or something similar?
ID:	292396   Click image for larger version
ID:	292397   Click image for larger version
Old 09-09-2011, 04:58 PM
catso's Avatar
catso
I'm pretty sure they changed the design in '87, so your '84 probably isn't interchangeable. Try searching at Mye28.com and see if anyone over there has done it.
![/I][/FONT]
Old 09-09-2011, 05:47 PM
IEbimmerguy's Avatar
IEbimmerguy IEbimmerguy is offline
Mein Auto: E38, e23, e3
What state are you in? I have a few clusters and can change the miles to your correct amount.
Old 09-09-2011, 07:26 PM
I am in Cincinnati OH
Old 09-11-2011, 07:46 AM
some parts for sale
I have determined that the gauge I have will not work in my car so I am selling it and some other parts I have.
The gauge is from a 88 535is $65
Floor mats from the same car (beige) $50
sport steering wheel $85
Window switches from 84 533i $3 each
Fuel door motor $10
If you have a request for a part, shout out, I might have it
ID:	292629   Click image for larger version
ID:	292630   Click image for larger version
ID:	292631   Click image for larger version
ID:	292632   Click image for larger version
ID:	292634   Click image for larger version
Old 09-11-2011, 07:56 AM
Here is a before and after of the mirrors and trim on the car
ID:	292642   Click image for larger version
Old 09-12-2011, 01:26 PM
Holzie Holzie is offline
Mein Auto: x-5 and 533i e28
Nice job
I have an 83 533i coming out of the paint shop soon. 121k and I am the 3rd owner.
I am watching your tips keep them coming
Old 09-18-2011, 10:25 PM
One of my headlights was weak and upon further inspection the glass was broken. It was a small hole presumably from a rock. I decided to replace my headlights all at once.
When I took the grill off the metal housing for the lights was rusty so I took care of that while I had it apart.
I used a brass wire attachment and a drill to remove the rust, then I painted them with flat black rust inhibiting paint.
I also decided to paint my faded grill pieces- same basic procedure as the mirrors.
2000 grit wet sanded and then painted with dupli-color trim paint.
ID:	293641   Click image for larger version
ID:	293642   Click image for larger version
ID:	293643   Click image for larger version
ID:	293650   Click image for larger version
Old 10-07-2011, 12:30 PM
I went to Indianapolis to pick up a valence and spoiler
They are not delphin, but close enough until I have my car repainted
ID:	296158   Click image for larger version
Old 10-07-2011, 12:40 PM
I removed my old valence and installed the "new" one... this is a big chore since you have to take the entire front end apart!
ID:	296160   Click image for larger version
ID:	296161   Click image for larger version
ID:	296162   Click image for larger version
ID:	296163   Click image for larger version
Old 10-07-2011, 12:43 PM
And here is with the new valence installed
ID:	296170   Click image for larger version
Old 10-07-2011, 01:26 PM
catso's Avatar
catso
Coming along real nice!
![/I][/FONT]
HTML code is Off
