Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 08-28-2011, 04:28 PM
Werner Werner is offline
Mein Auto: red one
Dash Lights out in Instrument Cluster
Just picked up the car and the fuses are fine but none of the instruments illuminate. Where should I begin checking? Thanks.
Old 08-29-2011, 05:07 PM
catso's Avatar
catso catso is offline
catso
Fusebox, battery, light switch, any and all electrical connections including chassis grounds, etc. Old cars are prone to corrosion and poor electrical contact. Corrosion can exist inside of the insulation where you don't see it. Get a test light. You may want to remove the instrument cluster and check the bulbs and connectors.
![/I][/FONT]
HTML code is Off
