Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 08-29-2011, 06:29 PM
rabbi333 rabbi333 is offline
Mein Auto: 135i conv
tires for 135i 255/40/18 vice 255/35/18
No replies to my original post on replacing the run flats on my 135i so after reading tons of post I decided to get the Mich pilot super sports. I went with the 225/40/18 on the front and was going get 255/35/18 on the back but the tire shop put on 255/40/18 instead.
what would the side effects be off having the 40's vice the 35's.
thanks
Old 08-29-2011, 07:53 PM
kyfdx's Avatar
kyfdx kyfdx is offline
Who, me?
Mein Auto: 2006 330Ci ZHP
thanks
It's a huge difference.. The incorrect tires are a full 1" taller than than stock.. They might work, but they might rub... It could throw off the stability control, because they aren't turning at the same rate as the front tires.
No way I'd run them that way..
2006 330Ci ZHP Imola Red
2011 X3 Bluewater
1995 M3 Montreal Blue
1987 325iS Bronzit (retired)
2011 Z4 Space Gray (retired)
2008 X3 Sapphire Black (retired)
2005 330Cic Silver-Gray (retired)
2003 325i Sport Steel Blue (retired)
1967 2000CS Delphin Gray (retired)
Old 08-30-2011, 08:55 AM
Rudy@Tirerack's Avatar
Rudy@Tirerack Rudy@Tirerack is offline
Moderator
Mein Auto: 1-800-428-8355 X4664
Originally Posted by kyfdx View Post
it's a huge difference.. The incorrect tires are a full 1" taller than than stock.. They might work, but they might rub... It could throw off the stability control, because they aren't turning at the same rate as the front tires.
No way i'd run them that way..
+1
Refer to 'Rudy/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by CLICKING HERE.
Rudy@Tirerack.com
Old 08-30-2011, 01:41 PM
thanks.. I went back and got the 35's put on..
Old 01-23-2013, 10:46 PM
snoboat1 snoboat1 is offline
Mein Auto: 2008 135i convertible
PSS sizes
Just curious how do you like your Pilots with the sizes you have on them, do they feel spongy or do they perform really well if you push them.
How is the comfort aspect ?
