e90 Resonator delete hurts Low RPM torque? - Bimmerfest - BMW Forums
Old 08-29-2011, 06:37 PM
BrooklynNY1015 BrooklynNY1015 is offline
Jarrett
Mein Auto: 2011 Camry SE I4
From what i have read at club lexus, completing a resonator delete to make your exhaust note "better" (subjective) actually takes away some of the torque your car has at lower RPMs. Is this true for any of the e90 sedans?
Old 08-29-2011, 06:51 PM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
I'm no mechanic, but I fail to see why that would happen.
Unless the delete somehow puts backpressure on the exhaust, but that would impact HP across the entire powerband, not just the low end. Right?
Old 08-29-2011, 07:02 PM
David Williamso David Williamso is offline
David W
Mein Auto: 2007 335I E93 & E92
Actually if the exhaust system is too large for the engine you will reduce the low RPM torque but in normal street driving you will never notice it. It will just piss off everyone else with the noise
David
Old 08-29-2011, 07:17 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Backwards: As David said, if there is too little backpressure, the exhaust gases escape the cylinders more quickly when the exhaust valves open, slightly reducing the useful duration of the power stroke and thus the gross torque.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 08-29-2011, 08:57 PM
Learn something new everyday!
Sent from my Droid using Bimmer
BMW CCA Member
Old 08-30-2011, 07:19 AM
boilers93 boilers93 is offline
Mein Auto: 2007 335i coupe stick
Yep, this would be my diagnosis. Turbo cars in particular are more efficient with a certain amount of back pressure. I could see how a resonator delete would diminish the backpressure to where the torque could be affected.
Old 08-30-2011, 07:39 AM
33beto 33beto is offline
Send a message via AIM to 33beto Send a message via Yahoo to 33beto
Mein Auto: 2008 E90 328i / GM 6L45E
I was thinking to replace the resonator with a dual in/single out Borla muffler, but i have yet to read anything regarding low end torque loss.
Doesnt the VANOS compensate for this?
Lou.
Old 08-30-2011, 08:20 AM
Mystic1's Avatar
Mystic1 Mystic1 is offline
Mein Auto: '11 328xi, '09 550i
I had a fairly modified supercharged vehicle, and others with the same vehicle that had replaced their stock exhaust with a free flowing cat-back system did indeed lose low end torque as proven on a dyno. When you lose back-pressure, the torque will decrease as previously stated. Now what engine dynamics are behind this, I have no idea, but it has been proven to be the case on other vehicles.
