E30 (1982 - 1993)
Old 08-30-2011, 01:26 PM
rhfrazier rhfrazier is offline
Mein Auto: 1991 325i
Advice on replacing Starter on a 1991 325i
Looking for advice, pointers, tips, pictorials and directions to replacing the starter on a 1991 325i. I've done some surfing giving details from all day to 2 hours to remove and replace. I have also read about nightmares, bad weather conditions and no manuals. I have a manual, the starter, but looking for some wisdom before I begin. The weather is great outside, however I will be doing this in my garage. Thank you in advance for the kind words of encouragement.:
Old 08-30-2011, 03:20 PM
downhiller's Avatar
livin large
the main thing is to stay calm and dont use the bfh.
Old 08-30-2011, 04:32 PM
damalex's Avatar
damalex damalex is offline
Mein Auto: 89 E30
Mine was a pain to put back on just cuz I couldn't get a wrench on one of the bolts behind the firewall so I found a old POS wrench an bent the handle so I could get of on an tighten it down
Sent from my ADR6400L using Bimmer
Old 09-06-2011, 08:26 AM
Completed the job satisfactorily
Thanks for the words of wisdom. They were of good use.
Old 09-07-2011, 07:27 AM
Oh yeah, I forgot to say that I too tool an old 10mm open box wrench and bent it 90 degrees at the end by the open box to be able to place it on the bolt behind the flange (totally out-of-sight but could only feel it with one finger). It took another person to tighten the starter motor bolts while I held the smaller 10mm bolts. I was also able to do this without taking the intake manifold off. Thanks to the community of DIY's and the comments which culminated to a sucessful install.
starter, starter motor
