Old 08-31-2011, 01:59 PM
datadave datadave is offline
Data Dave
Mein Auto: 535i V8
E39 Start Button
Hi to all I hope all are well.
This is my first post and I would be extremely gratefull if someone could help me.
I have just bought a start button for my 2000yr 535i V8 and have connected the relay up to the cigarette lighter. (power and used the illumination wires to illuminate start button as
well). I am just left with two wires from the main contacts of the relay that go to wires from
the ignition. On the ignition connector I have three red wires (permanently live) then 3 Green wires, 1 Violet and then 1 Black with Yellow stripe.
My question is to which of these do I connect the two wires from the relay to. I have seen some pictures on a forum but they had a couple of different coloured wires so not sure.
Hope someone can help as the button looks nice in the dashboard but doesn't do anything.
All the best everyone
Dave
Old 08-31-2011, 02:06 PM
five.two.five five.two.five is offline
Mein Auto: 2002 525I
Red: 12v Constant
Green: Ignition
Violet: Accessory
Black/Yellow: Start
Do you have the diagram for the button?
Old 08-31-2011, 03:53 PM
Data Dave
Mein Auto: 535i V8
Push button details
It is simply a 2 connection Press to make contact switch. There are another two for illumination which is working fine (fed from cigarette illumination wires). The other connections have power just to make (pressed or break (release) the relay contacts,terminals 85 and 30 I think. These are the connections that the two wires come from that I need to know where to connect to start car.
Cheers
Dave
Old 08-31-2011, 04:38 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
.but you still need the key in the ignition for the EWS.
Old 08-31-2011, 06:13 PM
SlorpBop SlorpBop is offline
'01 525iT
Mein Auto: L
Damn, I wish we had that 3.5L V8 over here in Canada/North America. I just watched a couple videos on youtube, sounds awesome. Do you know the curb weight of the 535i E39? One of the main reasons I am not a fan of the 540i is because it is so much heavier (~roughly 500lbs) than the 530i, while only gaining some 50-60hp. My favourite part of my E39 is the handling and I have always felt that the V8 would upset this.
Old 08-31-2011, 07:37 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Better check your figures again, only 254 lb weight difference, 540 has 65HP more and 110lb ft more torque.
Weight is with driver and full tank of fuel.
530 w/5 speed
3494 lbs
225 HP, 214lb ft torque
540 w/6 speed
3748 lbs
290 HP, 324 lb ft torque
Old 08-31-2011, 09:04 PM
'01 525iT
Mein Auto: L
530 w/5 speed
3494 lbs
540 w/6 speed
3748 lbs
Sorry my bad, I had read somewhere (unreliably) that the 540 was somewhere around 4,000lbs. And in my defense, the 540 only had 290 horse in the last 2 years of it's 7 year run, so it's more common 282hp iteration is within the ranges I said (I also had the Wikipedia stated Hp of 228 for the 530i, giving the 540i only a 54hp advantage). However, the incredible torque of 324lb-ft definitely makes all comparison irrelevant. Thanks.
EDIT: Wikipedia link of E39 engines - http://en.wikipedia.org/wiki/BMW_5_S...specifications
Old 09-01-2011, 06:33 AM
Data Dave
Mein Auto: 535i V8
Cool Sad I Know but love it all the same
Yes but you are not as sad or easily pleased maybe.
I have always wanted one but I know there is no time saving or practical benefit
for having it.
Cheers
Dave
Old 09-01-2011, 06:57 AM
DennisCooper!'s Avatar
DennisCooper! DennisCooper! is offline
Mein Auto: 03 Ex Cop 530d Touring
Hi Datadave,
If you get stuck or need some more help etc, I do know one of the Bristol area's best specialist auto electricians. He does his main work at the dealerships level mainly so the usual fare, BMW, Audi, Renault, Mercedes etc etc.
I'm sure he'd know exactly how to wire the start button in and get it all working and more importantly, fitted well and to high quality and thus safety, levels.
Please give Donald a call at Alarm a car ltd http://www.alarmacarltd.co.uk/contact-us and tell him I, Dennis sent you!!
Cheers, Dennis!
Old 09-01-2011, 07:47 AM
Your right about being practical, but I can probably say most of us (I6 and V8) didn't buy a BMW to be practical.
Anyway, back to your Start Button.
Your switch is p/n 61326901962 and mine is 61326901961. I think they are the same electrically, but you should confirm this with an ohm meter before you wire in the relay.
Does your ignition switch connector look like this? If so, it looks like you need to connect your N.O. relay contacts to pins 5 and 8 of the ignition switch.
5 is a red wire and 8 is a black/yellow wire.
Old 09-01-2011, 10:15 AM
Data Dave
Mein Auto: 535i V8
Brilliant detailed information.
Thanks I have been able to do it now and it woks fine.
Kind Regards
David
Old 09-01-2011, 03:45 PM
Data Dave
Mein Auto: 535i V8
Thumbs up Good Bristol Auto electrician
Originally Posted by DennisCooper! View Post
Hi Datadave,
Cheers, Dennis!
Thanks I have done it now but will keep Donalds details for future reference.
Thanks again
Dave
e39 start button, ignition circuit, starter
