Bank 5 misfire - Bimmerfest - BMW Forums
Old 06-14-2017, 06:45 AM
rsking rsking is online now
Mein Auto: 1997 528i
Bank 5 misfire
Ok Folks
I have a 2003 745li about six months ago I had a major engine overhaul
Valve stem seals
All related gaskets
Spark plugs
Ignition coils etc.....
Over the past two months I have been getting an engine warning of reduced power ran a scan and found that bank five was misfiring
So I replaced the spark plug witch mind you was still fine and the car idled fine for 24 hrs
Again it began to misfire, so I took a good look at the coil and still good. Took the plug out and put it back in. Idled fine for about two hours then it misfired again.
Any ideas this becoming extremely frustrating
Old 06-14-2017, 06:54 AM
Ltmax's Avatar
Ltmax Ltmax is offline
Mein Auto: 2008 750l
Might be as simple as a bad ccv letting oil into the intake and down into the engine. First plugs to get fouled are 1 and 5. I'd start there and see, also pull that spark plug and make sure the gap is correct and swap that coil with another cylinder to confirm the misfire isn't just the coil going bad.
Good luck
Old 06-14-2017, 08:21 AM
Good luck
Thanks for the reply, I have replaced both CCV when I had the overhaul done. I will swap the coil today and see if that works.
That would be crazy if that's the solution because These coils are less than a month old
