Old 09-02-2011, 08:27 PM
kcbimmer86 kcbimmer86 is offline
Mein Auto: 12' BMW X535i Premium
2012 BMW X5-Location of Oil Filter and Drain Plug
hi all, i was just curious, would anyone know where the oil filter and the drain plug are located? obviously, the drain plug is located under the car but under which trap door? has anyone ever try changing the oil by themselves (if not covered by warranty) or has a good DIY-i would love to read it.
Old 09-02-2011, 10:02 PM
rattmann rattmann is offline
Mein Auto: 2011 TURBO X5 35i
How can you not see the big old oil filter under the hood? Hint: Not under the car!
Old 03-15-2013, 09:54 AM
DCC DCC is offline
BMW Fan
Mein Auto: '02 Z3 M Coupe
The oil filter is up top and you will need a large filter cap tool to remove. I find the original BMW unit has the best fit.
Did you find the correct oil drain bolt in the bottom? It is the regular bolt looking one that needs a socket to loosen. Not the ones that uses a hex bit.
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 03-15-2013, 12:34 PM
RockChips RockChips is offline
Mein Auto: 2008 X5 3.0si
If you are trying to do an extra oil change, you can pay for it out of pocket.
Just tell them not to reset the computer!
