Old 09-04-2011, 05:38 PM
jcf jcf is offline
Mein Auto: 135i
Replacing RFT
Best tire to replace RFT for 135i 18" wheels
Old 09-05-2011, 12:43 AM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Any..... nothing is worse than rft
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 09-05-2011, 05:29 AM
peakpro's Avatar
peakpro peakpro is offline
Mein Auto: X5 3.0/987S/997
michelin super sports
Old 09-05-2011, 06:22 PM
sd330Ci's Avatar
sd330Ci sd330Ci is offline
Mein Auto: BMW 1M, MINI Countryman S
Love Michelin PS2 - best tires I had.
Did not try Super Sports yet.
Old 09-06-2011, 02:25 PM
SilverX3's Avatar
Kumho KU31.... best value for money
Job - Captain
MY11.5 X1 Xdrive25i
Old 10-31-2011, 12:41 PM
135nRXP 135nRXP is offline
Mein Auto: 2009 135i
I swapped them out with the Hankook V12 EVO and they are an awesome tire for the money. I went wider too... 235 front and 265 rear on the stock 261 style M-Sport wheels.
09 135i, A6, Monaco/Coral Red, M-Sport pkg, Premium pkg, Hi-Fi sound, Procede Rev3, DCI.... PWM Meth kit waiting to be installed
Old 10-31-2011, 12:51 PM
jcf jcf is offline
Mein Auto: 135i
Thank you all for the suggestions
Old 10-31-2011, 12:53 PM
jcf jcf is offline
Mein Auto: 135i
I have 2009 135i. Did wider tires cause any problems with fenders?
Old 10-31-2011, 12:55 PM
Nope, no issues with mine. That's about the limit you can go before you start to run into issues with rubbing.
Old 11-10-2011, 07:38 PM
Nash_39 Nash_39 is offline
Mein Auto: 135i
I'm interested in wider front tires too. Did you go with the 35 profile 235s to stay close to the stock circumference or just use 235/40s and put up with a bigger tire ? I can only find a few 235/35s out there and most aren't good competition choices.
Old 11-11-2011, 05:07 AM
I went with 235/40 and 265/35 sizes. They are just a tad bit taller, but that actually helps with allowing the tires to soak up minor surface irregularities.
Old 11-11-2011, 06:48 AM
Norm37 Norm37 is offline
Mein Auto: Chevy half ton pickup
Good to hear! Those are the tires my son is thinking about getting in the spring.
They took second place in this Car and Driver test.
http://www.caranddriver.com/comparis...12-evo-page-10
He has the Michelin Pilot Alpin PA3 performance winter tires on now.
Old 11-11-2011, 01:33 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
Thread should have ended at post #3. If you said best value, we could sit here for longer, but even then I think the PSS would have a good chance. The price difference over the V12s will be less than $300 on all 4 if you factor in the on going promo's, but you will have the best performing tires available, and perhaps have longer tire life (hard to say I think because you can't compare UTQG across brands?). The PSS will have a 0.5" wider tread in the front, and 0.8" wider in the rear. They weight 1 lb less in the front, but 2 lb more in the rear.
The PSS outperform the PS2 in every regard, and have been said to match the Conti DW for wet performance. The CR UHP summer tire test had the PSS head and shoulders above. #2-#7 were separated by only 4 points, but PSS was ahead of #2 by 8 points.
I greatly considered the V12s as well, they are a great value it appears. The TR Price Pledge Plus shop that installed my PSS said the Hankooks were an extremely popular sell.
However, the "best" to me regards performance only. For some, it seems that they equate that with softer/cushier/number, well I suppose if they live with war torn roads. The PSS are not very soft, only subtly more forgiving than the RFTs in my opinion. Others may disagree; but if you want cushy, there are better choices for that.
Old 11-14-2011, 09:09 AM
Bethesda E39's Avatar
Bethesda E39 Bethesda E39 is offline
Mein Auto: BMW 1 Series
I bought 17" Hankook Ventus V4 to replace my stock 128i RFTs,and couldn't be happier. $450 for all 4, including install.
