Old 12-03-2015, 08:42 PM
Avila97 Avila97 is offline
Mein Auto: 03 bmw 530i
My car won't start
Hey my 03 530i won't start. The car battery seems to not hold the charge. I jumped the battery and left it overnight next morning it didn't start but the dash lights came on. I bought a new battery thinking that was the problem but it's not. I don't know what else it could be. I tested the alternator and that's not the problem.
Old 12-03-2015, 08:52 PM
Brandon002's Avatar
Brandon002 Brandon002 is online now
Mein Auto: 2002 530I Sport
Does it crank? You're going to need to provide a lot more details before anyone can even begin to help.
Old 12-04-2015, 12:21 PM
Yes it clicks line it wants to start but it doesn't
Old 12-04-2015, 02:23 PM
sixpot_simon's Avatar
sixpot_simon sixpot_simon is offline
Mein Auto: E30, E39
Hi Avila,
Check out the Battery Drain section of the wiki: http://www.bimmerfest.com/wiki/index...#Battery_drain
What voltage was the new battery when you first tried to start it?
Then what did it drop to in the morning?
Does it have any aftermarket electrics (eg stereo or alarm)
Has any work been done to the car recently? Or any other problems?
Old 12-04-2015, 02:46 PM
SSJRICH 540i's Avatar
SSJRICH 540i SSJRICH 540i is offline
2000 M5
Mein Auto: '00 M5
First, did you buy the right battery? 49 series? Did you make sure that the battery you bought was fully charged?
How did you test the alternator if the car didn't start? Assuming that you jump started your car, how did you test? What voltage were you getting?
When you say clicks, do you mean cranks, or literally clicks. If it cranks and doesn't start, is your security light on while you crank?
Have you scanned the car for codes?
Current - '00 M5 - '02 530i M sport - '02 X5 4.4i Sport - Old - 00 540i/6 M sport -Old - 97 540i/6
Old 12-04-2015, 09:30 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
hi avila..youll need a little bit of test equipment here, mainly a voltmeter, cheap enough. first off, charge the battery overnight, then read the voltage. it should be 12.5+. after starting the car, with it running, read the voltage at 1500 rpm or so, it should be 14v thereabouts. when sitting overnight, does the battery voltage drop? with the headlights turned on, engine off, does the battery voltage drop much? that kinda covers battery, charging and parasitic drain probs, but your description of the problem doesnt give much to go by.
99 528i 5sp sport
