X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
#101
eeekkkk... You shouldn't have had to take off the metal cover... Thats why I tore mine apart, so people could see. There is no need to take the cover off, just turn the gear around.
#102
2 things. Are you sure that this is the problem? The 4x4 light should have gone off as well. Also, when you did the gear turn, did you turn it 180 degrees? If you only turned it 90 degrees it is likely that the gear is still in the damaged portion.
#103
I thought pb suggested it is not necessary to take the cover off the actuator in order to rotate the white gear 180 deg.
Unless you really want to clean up the shavings. I could be wrong as I haven't done this myself. Mark the position and then use the worm gear or something else to rotate it? And as I understand it, it isn't necessarily the cure for all instances of the triad of lights. Just where the clicking sound is heard after shutting the engine down? |
#104
lol. yea i took it off anyway. i wanted to clean out the shavings and i wanted to be sure that the worn down piece is completely on the opposite side. wasn't too bad. just had to tap it back into place.
so i had my mechanic rotate the gear 180 degrees in the actuator. This resulted in the ABS and Brake light going away, and he confirmed the XDrive was working, but the 4x4 light didn't go away. After driving it around for around 100 miles, the ABS and Brake light came back on. I also started hearing the honking noise after turning the car off. However, I also started getting friction/feedback/shaking on my wheels when turning slowly to the left or right, almost as if something was wrong with the 4x4.. has anyone felt this before?
I felt this a couple months ago (the friction/shaking on wheels when turning) when the 3 lights first showed up, but it went away. Has anyone experienced this? I am starting to think I just need to replace the actuator with a new one (or that my mechanic didn't fully rotate the gear 180 degrees).
2007 X3 3.0si Minivan / Alpine White / Black Leatherette / Brushed Aluminum / Steptronic Transmission / Navi / Xenons / Premium Sound / 18" 205-Style Wheels / Ordered 4/4, Production complete 4/16, ED Pickup 5/15, ED Dropoff 5/24, Arrived on Integrity 6/17, VPC 6/19, Released to Carrier 7/9, Re-Delivery 7/12! |
#106
Jay,
How did the top off and when you reassembled the part, was the rubber seal hard to get back on? |
#108
so even after I rotated the gear, I was getting the lights inconsistently.... i ordered a brand new actuator and replaced it and now my car is fine. sucks that I had to blow $700 instead of having this workaround actually work.
#109
Actuator Motor Access Issues
I've been experiencing the "3 Light" issue along with the "clicking" noise when turning off ignition. Got up under the car this evening to remove the actuator motor and turn the gear to see if it would resolve the problem but ran into access issues. I've got a support bar and a splash guard that runs from just past the transfer case to the rear bumper that is limiting my view and ability to get a socket wrench to the torx bolts. From the sounds of it, some of you have had a pretty easy go at getting to the motor and getting it off. Is my undercarriage cluttered more than yours or am I failing to see the easy route. Any suggestions would be appreciated.
#110
So I did the roation of the gear fix and it worked until this afternoon. I got the three dash lights to go on. After looking around on the web for any new potential news/fixes came across this eBay listing ( item #130632900391). Anyone try this or have any new leads on someone that can make a rebuild kit/gear?
#112
my god.. thats my picture....
#113
I didn't even notice, well I figured it was to good to be true and I guess I'll be just replacing the whole actuator this time around.
#114
you can get them for copyright infringement and ask for damages $$$$ or at least to lower the price a bunch!
#115
I am in canada, montreal i turned the black gear 180 and its been 4 days now and no problem runs fine in the snow and all around
#116
I turned the black gear 180 and it works fine i am in canada alot of snow here and had no problems
#117
That's great it worked for you, It had worked for a few months for me. I suspect my failure is mostly due to my drivin style. My wife describes it as spirted lol. When I did the rotation I noticed that more then half( closer to 2/3 ) of the black gear had a noticeable "u" grove in it. I fully expected to have to replace the gears(if a kit became available) or the whole actuator.
#118
I bought one some months ago. Perfect on my X5 4.4i. |
#119
Hello
if you read this post i was the first to try this solution back on sep 2011 everything was fine until today it last 4 month i took it out and the gear was stripped in the other half so the question is to buy the whole actuator or just the gear that its posted on ebay ? any advice Last edited by dannyy06; 01-28-2012 at 02:06 PM. |
#120
It's not necessary to buy whole actuator because it comes with same materials. You just need the gear posted on ebay. I can confirm it's a very high quality replacement kit, bronze alloy, indestructible. It come's with a detailed guide to install kit from yourself. I'm very satisfied. |
#121
Guide comes with package.
Thanks |
#123
Just a reminder...
Before folks start using an indestructible metal gear in the transfer case, they may want to go back and review the portion of this thread where some of us pondered the wisdom of this choice over the original plastic gear (Posts #85-87).
A metal replacement gear will be far more durable, without question, than the original plastic gear; but BMW may have deliberately intended that a plastic gear be used in this application in order to protect the more expensive components (e.g., the actuator motor), should the transfer case system become jammed for some reason: the relatively inexpensive plastic gear becomes what's called the "design failure point" and more expensive components (like the actuator motor) are spared failure/burnout. Of course, this is all well and good -- if one can obtain the failed component (i.e., the plastic gear) without having to purchase the entire transfer case from BMW... But the fundamental point I'm trying to make is that, by replacing the plastic gear with a metal one, one needs to realize that they run the risk (however slight) of damaging other components in the transfer case or xDrive system should a situation arise where the plastic gear would have ordinarily failed in order to protect those other components...
X3 w/6-speed & Sport Package: A sports sedan disguised as an SUV... |
#124
these components are tested and certified for more than a year.
#125
Which components...? The metal replacement gears...? I have no doubt that they'll last...
That's not the problem I'm talking about, though... The problem I'm describing would arise if mechanisms in the transfer case or xDrive system became jammed for some reason. BMW likely designed that gear to be made out of plastic for a reason other than just to save a few dollars in production costs (although that would have been an additional motivator for them...): it's probably supposed to fail if the system becomes jammed, thereby preventing damage to high-dollar components of the transfer case/xDrive system. A metal replacement gear is not likely to fail under those same circumstances, leading to potential damage to, or failure of, another (probably more expensive) system component -- like the actuator motor. Now, acknowledging that it's easier said than done in this case, my opinion has become that it's ultimately better to seek out an original plastic gear for this repair, if it becomes necessary (and "pburnett's" 'quick-fix,' outlined at the beginning in this thread, does not do the trick). But folks are certainly free to use the metal replacement gear at their own risk; in most cases, it will probably work out fine for them -- unless they're unfortunate enough to 'win' the lottery where something binds in the transfer case or xDrive system... Just trying to keep people educated about why some decisions (e.g., the use of a plastic gear inside a transfer case) are made in the world of engineering when on the surface, it seems as if they were made in the world of finance... Carry on...
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
