X3 E83 (2004 - 2010)
Talk about the E83 BMW X3 in this forum! |
#176
![]() Thanks |
#177
The cross member supports the transfer case. The cross member could be removed but that would mean another type of support for the transfer case or a complete removal of it. The exhaust is still there and in the way of the removal of the brace also. It is much more work to me to remove the brace alltogher and not needed. I have ordered a new actuator and when it arrives will do a write up with pictures. Keep in mind this is just how I did it and I'm sure there are other ways. In total it took me longer to figure out how to take it all apart then to do the fix. This time I'm sure I can remove and replace the actuator put it all back together in two hrs time.
#178
Brake, abs, 4x4 lights lit up
Yesterday I had the misfortune of viewing the 3 lights on my dash indicating a potential problem with my transfer case actuatorf. After do my due diligence on various BMW blogs I settled into the fact that I would soon be visiting Hans at my local BMW dealer, but to my surprise this morning, the lights went out and the car stopped struggling with its rear end.
Does anyone out there think that this intermittent problem could be caused by a corroded conector.? One would logicaly think that the transfer case actuator is working or not working, right. ?? Any comments would be appreciated. Norm... |
#179
norm w - I would not automatically assume you have the same worn gear problem which is the main topic of discussion in this thread. As far as electronics, there are two related components on an X3. P/N 2760759988 is the control unit for the transfer case, and P/N 27107557345 is a resistor which on the realoem.com diagram seems to reside on the actuator end.
BTW, I talked to one of the BMW indie techs in this area and he said he's swapped two X3 actuators. Both cars had uneven tire tread depths. I have to admit, I have that issue as well...three older tires, and one newer tire. I wonder if fractions of a mm can cause so much stress on the actuator. Wouldn't uneven inflation pressures amount to similar differences in the wheels' overall diameters? When I mentioned to him this may very well be a design flaw given the number of folks experiencing the problem, he pretty adamantly refuted. Regardless, one would expect this component not to be so sensitive but a bit more robust. |
#180
Finally, after a 10 hour marathon starting Friday evening, I was able to carry out the 180 deg rotation. Lights are gone - have driven 25 miles since the fix.
I'm curious what is the most miles anyone has driven since this fix without a subsequent issue. 25K miles? 50k? I took some pictures of the alleged culprit gear. Interestingly, at least to me, it looked very similar all the way around (360 deg.). That said, the issue does seem to be fixed, even if temporarily. This job is all about underneath access and tools. It is the most difficult thing I've done on this truck. If you don't have access to a lift, please be careful not to strain your shoulders or neck. If the fix lasts for at least 50K miles, it is certainly worth the trouble. |
#181
Another related observation and question for the community...
Now that the 4x4 system is working again on my X3, I have resumed noticing a parking feature which was notably absent during the few weeks the 4x4 system was out (truck was on 100% rwd). When I come to a stop and shift the transmission to "P," there is usually a "thud" that comes from the drivetrain, accompanied by the slightest nudge of vehicle to the rear. It is as if the transfer case actuator gear adjusts itself by a tooth when the vehicle comes to a stop and is parked. Anyone else notice this? Is this normal? Is this the cause of the gear wear? What causes this? Is this related to unequal tire tread depth? |
#182
Removal
Great thread, appreciate the fix for a common issue. Does anyone have instructions for removal (where it is under the car, step by step how to remove it)? It seems some are able to get it right off of the car while others are having a difficult time. Thanks!
#183
Transfer case problem
Hello everyone...need some help.
2007 X3...accelerates fine...no sound at 50-55 mph and release the accelerator have a roaring sound, not actually a vibration but a roar, no clunking or big sounds, just a roar. Car will not do it at any other speeds, go 70-75 and release accelerator--no sounds....go 40 mph and release accelerator---no sounds...Anyone got an answer...car has 69000 miles on it. Thanks |
#184
Transfer case actuator motor assembly
![]() ![]() Thank you sooooo much for the post. I followed the instructions and it is now working. However like someone posted I am not sure if it will work once 4X4 is asked for, but the 4X4 light went out. In addition I made sure to clean everything carefully and relube. Someone was wondering if the black gear goes bad because the load is too high. I found 3 cracks in the white nylon gear as well. This will cause it to expand, in turn causing slippage and perhaps make it go stuck, but for now it is fine. I could perhaps have tied some metal wire around the white gear hold it together. Lars |
#185
Update to repair
In my former post I said that I noticed 3 cracks on the bottom of the white nylon gear.
I decided to take it apart again and reinforce the gear with a sleeve. I found a 1 1/4 inch brass drain pipe that fit exactly. Not only is it very thin so that it doesn't interfere, but it is just small enough so that it tightens up the cracks in the gear. I decided to reinforce the top of the gear as well that connects to the transfer case. I feel that the nylon gear in the cause of the problem. When the black gear tries to turn it, it expands enough for the teeth to get stuck. I have attached pictures to explain. Hope this helps. Lars |
#186
I found this site and I really thank you all for the input. My 08 X3 started making the clicking sound Saturday morning, took it to a local shop where I live (not BMW). They said it was coming from the transfer case area. Made an appointment at the BMW dealer to confirm the noise. I get no dash lights so I hope that it is the same problem or less that you all have said. Great site and a very awesome tread about this problem.
#187
Is it model year dependent, transmission type or something else? |
#189
Got a new one today for 670.00 out the door and dealer will put it in for 117.00.
#191
Conclusion / Resolution
Okay here is the bottom line: The car is fixed using the workaround in this link: http://www.bimmerfest.com/forums/sho...d.php?t=566880 Cost: Mechanic replacing transfer Oil that BMW says for life $93. BMW diagnostics to make sure it is the Transfer Case that is damaged: $135 1 Hour labor for a friend mechanic who agreed to do the workaround: $65.00 Total $293 vs. $1700.00 BMW estimate You can save all of this money if you have the courage and patience to do it all. i would have done it if i had another car! You definitely need the lift or the job will take half a day .. you definitely need to take the actuator out because other wise its very hard to see the damaged area and 180 degrees is not holy look into the actuator motor and you will be able to see the damage rotate until you see the damaged area gone Drove it 100 miles since the fix and it rained hard .. no problem .. flies like new .. Thanks PBURNETT!!! |
#193
Well....
I am now back to the original issue which is: When I start up the car, I get a squealing sound like a belt slipping. When it began, I would quickly shut off the engine, turn it back on and the sound would be gone and the car would operate normally. Few days later when it happened I decided to leave the car running, open the hood and look at the serpentine belt. The sound didn't seem to come from there however. I then got back in the car, turned it off and on again. THis time however the 4X4 light was on. When I backed it up carefully it stopped by itself after say 20 yards. I then tried going forwards with the same results. Given the car a little power I heard some bad sounds from underneath. This is when I stopped and eventually repaired the actuator. Now I am back to the intermittent squeal. I am afraid that the transfer case is bad somehow. I know there is a chain in there, which I wouldn't think could produce a squealing sound. I am perplexed!!!! |
#194
Also, which BMW dealer is willing to put it in for $117? That is an excellent price. Here in the DC area they would have charged at least 4x that price. Make sure they re-program the car (the new actuator needs to "adapt" to the car). |
#195
Good for you! You'll probably need to eventually replace it anyway. This is probably the most useful thread on the X3. However, I wish eventually other more knowledgable subiscribers can answer the following questions about the actuator: 1. Why does a 180 deg fix the problem? Does the worn gear in question NEVER rotate more than a few degrees relative to it's set point? What does the rotation of this gear while driving actually accomplish? Vary the engine torque between the rear and front axles? 2. Has anyone obtained > 25K miles after the rotation? One subscriber had to replace the actuator within just a few months of rotation. 3. When you hit the 4x4 button on the dash, is this actuator completely disengaged from the driveline? Meaning, no load on the worn gear in question? One question for you: On http://www.basneypartsonline.com, the price I see is $900.31 - do they only give you the online store price if you actually physically walk-in? I am wondering if there's a way I can use their excellent prices for my future needs
#197
Well, I'll give it a crack...
I don't believe anything (short of a malfunction or failure of the transfer case gear) can fully disengage the xDrive system; it's a full-time all-wheel drive system.
X3 w/6-speed & Sport Package: A sports sedan disguised as an SUV... |
#198
that's why you get the hesitation on take off uphill .. triggers the 3 lights ... or when road is slippery .. that also turns the 3 lights on they are not on all the time ... only when awd is kicking in .. just a thought ... |
#199
#200
That is the xDrive system which, as you noted, can't be overridden. However, it seems that the sole purpose of the transfer case actuator is to allocate torque split between the front and rear axles. It does not involve itself either in braking or in throttle input reduction. Now, my question is when you toggle the 4x4 button on the dash to it's off position, is the subject actuator not in play? One would logically conclude this based upon the emblem and dash light display assigned to this button. I do understand that other components of the xDrive, viz., selective braking and throttle reduction are still active. This is the only conclusion which makes sense to me, but I am not sure and therefore picking on others' brains. What I am leading to is this: IF this conclusion is correct, one can get a lot more mileage out of the rotated actuator by keeping the 4x4 button off. I think what'll happen in such a situation is that the vehicle will be RWD, but all other components of the xDrive system will still be active. Of course, keeping the button permanently off defeats the whole purpose of buying a 4x4 vehicle in the first place, but at least I want to know how the system works, and I want to use it as I please. Certainly it is recommended to drive with the system on in rainy or snowy conditions with the exceptions as noted by BMW. Am I right? Way off? |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
