Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 09-07-2011, 01:51 PM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: Black Sapphire BMW Z4 3L
Main Drive Belt
Hi Does anyone have a view as to when the alternator and the aircon belts should be changed? They seem to be in good condition but would consider doing it as a preventative measure.
thanks
Does my bum look good in this !
Old 09-07-2011, 09:41 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Belts typically last about 60K miles. You can easily check their condition using a bright flashlight. Look for small cracks or a shiny surface, which always develop long before the belt fails.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 09-26-2011, 10:00 PM
brown370 brown370 is offline
Big Mike Brown
Send a message via AIM to brown370
Mein Auto: 07 BMW X5 4.8i
I was told by my BMW service rep, the the belts on BMW can easily go over 100K miles and he has yet to see one car come in with broken belts under 100K miles. I changed mine at 90K, because my serpentine belt got noisy. It started whining because oil got on it.
11 Audi A5 2.0T 8 Spd Tripotronic w Sport Pkg, 19" Anthracite Wheels
12 VW CC 2.0T [/B] stock
05 VW GTI 1.8 T 5 Spd, Coilovers, Big Brakes,
(Previous rides)
04 BMW 645 CiC Auto
97 VW Jetta Jazz 5 SPD
06 Mazda 6 Grand Sport Auto
05 BMW X5 3.0 6 SPD
05 Infiniti G35 6 SPD
04 Volvo S60 "R" 6 SPD
99 Nissan Maxima 5 SPD
91 Nissan 300ZX 5 SPD
92 Honda Prelude Si Auto
76 Fiat Spyder 124 5 SPD
Old 09-26-2011, 10:08 PM
hipertec hipertec is offline
Mein Auto: 2005 645ci
So how do you change these belts
Sent from my Transformer TF101 using Bimmer
2005 BMW 645ci - DPE 3pc Forged Rims, Coilovers, Britalman full cat-back exhaust system, , K&N Air Filter, LUMMA Roof & Trunk Spoiler.
Old 09-26-2011, 11:23 PM
Big Mike Brown
You will need a sepentine belt tool w/ a large Torx socket T-55. To remove the sepentine belt first (lest than 10 minutes) Take a picture of the belt before removing it so you know how it goes back on.
Jack up the car and remove the front underbody cover. You use a towel to remove the A/C compressor belt while turning the crank/engine. One you remove the old A/C belt, put the new belt over the crank first, and then install it on the bottom of the A/C compressor and install the tool pictured on the A/C compressor pulley. Turn the crank clockwise keeping the belt tight and the tool will pop the belt on. I had to do it twice because the belt ribs did not line up the first time.
I need to do a DIY on the job.
ID:	294853   Click image for larger version
(Previous rides)
04 BMW 645 CiC Auto
05 BMW X5 3.0 6 SPD
Old 09-26-2011, 11:29 PM
Big Mike Brown
I attached the BMW PDFs for both jobs in the previous post.
BTW, use OEM belts. They last over 100K miles. I used a aftermarket A/C belt and it shredded in under a month.
Hope this helps!
(Previous rides)
04 BMW 645 CiC Auto
05 BMW X5 3.0 6 SPD
