Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series / 2 Series > E82 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by either an inline 6 in the 128 or the twin turbo rocket sled 135.
Old 09-10-2011, 08:55 AM
JejuneLegume JejuneLegume is offline
Mein Auto: 135i MSport
Exclamation All four rotors warped after a few thousand miles
After a few thousand miles began experiencing vibrations when braking.
According to the dealer all four rotors needed replacement because they were warped (the rotors).
Not real confidence inspiring.
I went ahead and replaced the front rotors with drilled-slotted rotors. If those hold up for more than a few thousand miles, will probably upgrade the rear rotors also.
Old 09-10-2011, 09:27 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
Brake rotors almost never warp: https://www.bimmerfest.com/forums/sh...3&postcount=17
Drilled rotors are, with modern pad composition, not much more than aesthetic improvements. The original idea behind it was to allow off-gassing from the brake pads to escape, back in the 60s. Modern brakes really don't off-gas that much. Slotted are roughly the same story: http://www.8thcivic.com/forums/suspension-brakes/92039-cross-drilled-rotor-myths-dissolved.html
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
Old 09-10-2011, 01:25 PM
rpsz4's Avatar
rpsz4 rpsz4 is offline
Mein Auto: 2008 135i
I have personally found that if you tighten the lugs to correct spec. with a hand torque wrench, the rotors will not warp. If some jackleg uses an air impact gun with a torque stick, they will warp. No matter how good they claim the torque stick is, they can not guarantee that each lug nut receives the same NM.
K4RPS 2008 135i. Z4 gone but not forgotten
warped rotors
