Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 09-09-2011, 03:38 AM
wld735i wld735i is offline
Mein Auto: 1988 735i bmw
88 735i - Transmission problem
hi when my 1988 735i changes gears it jolts into every gear its a automatic and it dosnt matter if its changing up the gears or going down it jolts in every gear please any help would be greatly appreciated
Old 09-09-2011, 04:03 AM
drivinfaster's Avatar
drivinfaster drivinfaster is online now
bimmerfest Supporting Member
Mein Auto: rescued bmw's
did you check fluid level and condition?? that should be the first order of business.
df
Old 09-09-2011, 04:00 PM
Yes iv checked the transmission fluid and there's plenty in there but still nothing
Old 09-25-2011, 06:39 PM
taralynn taralynn is offline
Mein Auto: 1998 740il & 1987 325 is
Check the mounts
Sent from my VM670 using Bimmer
Old 09-29-2011, 06:30 PM
berty25 berty25 is offline
Mein Auto: 1993 740i
Shaft Flex Disc
Check the drive shaft flex disc. This disc connects the drive shaft to transmission, its' made out rubber. I had one replaced because it was dry rotted. Could be your problem.
Old 09-29-2011, 06:36 PM
Check the drive shaft flex disc. Location; connects the drive shaft at the transmission. I replaced mine on a 93 740i because it was cracked and worn.
Old 11-10-2011, 01:53 AM
hi thanks for replying would it be hard to check the drive shaft flex disc and the mounts would i be able to do it myself?
Old 11-10-2011, 03:22 AM
yes, if you are able to securely get under the vehicle.
the flex disc is also called a guibo, and i am sure there are plenty of pictures depicting worn units in the forum, or online.
good luck.
df
Old 11-16-2011, 05:40 PM
To check the mounts open the hood put parking brake on and press down on brake pedal with left foot & hold, start car put n drive continue holding brake while
Also pressing down on gas pedal watch to see if your motor raises . If it does your mounts are bad. They are very easy to replace.
