Old 09-10-2011, 08:55 AM
JejuneLegume JejuneLegume is offline
Mein Auto: 135i MSport
Exclamation All four rotors warped after a few thousand miles
After a few thousand miles began experiencing vibrations when braking.
According to the dealer all four rotors needed replacement because they were warped (the rotors).
Not real confidence inspiring.
I went ahead and replaced the front rotors with drilled-slotted rotors. If those hold up for more than a few thousand miles, will probably upgrade the rear rotors also.
Old 09-10-2011, 09:27 AM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Brake rotors almost never warp: https://www.bimmerfest.com/forums/sh...3&postcount=17
Drilled rotors are, with modern pad composition, not much more than aesthetic improvements. The original idea behind it was to allow off-gassing from the brake pads to escape, back in the 60s. Modern brakes really don't off-gas that much. Slotted are roughly the same story: http://www.8thcivic.com/forums/suspension-brakes/92039-cross-drilled-rotor-myths-dissolved.html
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 09-10-2011, 01:25 PM
rpsz4's Avatar
rpsz4 rpsz4 is offline
Mein Auto: 2008 135i
I have personally found that if you tighten the lugs to correct spec. with a hand torque wrench, the rotors will not warp. If some jackleg uses an air impact gun with a torque stick, they will warp. No matter how good they claim the torque stick is, they can not guarantee that each lug nut receives the same NM.
K4RPS Z4 135i gone but not forgotten replaced with a '13 X Drive X1.
warped rotors
