Old 09-12-2011, 10:48 AM
bkgreene39's Avatar
bkgreene39 bkgreene39 is online now
Mein Auto: 1998 BMW 528i
Coolant Question
I was looking through the e39 faq did not find what i was looking for, so therefore im posting this question. Im sure this question has been asked a billion times before, besides the oem bmw coolant what coolant brand do you use, i have a 1998 bmw 528i production date 1/1998. Very good read about when to change your coolant i found in the faq, it links you to pelicanparts site. Props to the poster.
Old 09-12-2011, 10:54 AM
dvsgene dvsgene is offline
Search, Read, THEN Ask
Mein Auto: 98 540i M62 3.15
It's as controversial as what oil, spark plugs or distilled/tap water to use.
Most who do not use BMW will recommend Prestone All Makes or Zerex G-05.
BTW, by FAQ did you meant the Best links page? Because it is IN THERE: (under what coolant to use)
http://www.bimmerfest.com/forums/sho...8&postcount=38
Suggest you bookmark this link it for future reference.
Old 09-12-2011, 11:15 AM
bkgreene39's Avatar
good stuff, no i wasnt looking at the very best links, i was looking in the e39 faq section thought it might be there.
Old 09-12-2011, 11:19 AM
bkgreene39's Avatar
what about peak global lifetime 50/50 in the gold bottle with red cap
Old 09-12-2011, 11:36 AM
Yes, I've heard that is acceptable too. Better than the Peak in the blue bottle ones. Supposedly, the Peak GL is closer to the Zerex G-05 formulation. Also hear that the GL is harder to find then the Blue LL ones.
Old 09-12-2011, 11:43 AM
bkgreene39's Avatar
i guess im lucky i can acquire the peak global lifetime gold bottle at a local rite aid near my work, appreciate the input
Old 09-12-2011, 11:48 AM
It would be better and cheaper to get the Full Strength and a bottle of distilled than the 50/50 mix. Bottle of distilled is only $1-$1.50 in most places.
Old 09-12-2011, 01:31 PM
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
My local NAPA store stocks Pentosin Pentofrost NF. I have heard several say they think Pentosin makes the BMW antifreeze/coolant. I don't know this for a fact so do your own research. I just bought a bottle (full strength) for just over 14 bux.
http://www.pentosin.net/pressrelease...frost_NF_2.pdf
2002 530i
Old 09-12-2011, 02:10 PM
Joe@Bavarian Joe@Bavarian is offline
Mein Auto: Me - E39 5spd, Wife - E36
50/50 just means they add the distilled-water for you. I would recommend getting the full strength and adding the dis-water yourself. Don't forget to do your "cooling system overhaul" if it has not been done yet.
Old 09-12-2011, 03:05 PM
530iman's Avatar
530iman 530iman is offline
Mein Auto: 2001 bmw 530i E39
I use Prestone and mix with distilled water from any grocery store, you should look up the proper flushing method on the forum, it consists of turning the heater on low or something of that nature. That will ensure no old coolant mixes with the new coolant. The prestone I use say (All Makes and Models) on the bottle, it also states mixes with other colors of coolant, I have used it for two seasons, every winter with no probs.
19x9 and 19x10 et24 w/spacers= et9 Style 95 on conti sport¦ Stock non sport susp ¦ Black grill ¦ Black badge ¦
Old 09-13-2011, 12:14 AM
In the bestlinks is this reference printout for all dozen fluids:
- Glovebox printout: BMW E39 fluid summary printout for your glovebox (1)
Specifically, there's this thread for the coolant:
- Coolant: Coolant, for engine, automatic transmission, power steering, and AC evaporator cooling (1) & bleeding (1) (2) (3) or refilling DIYs (1)
Summary:
E39 Engine coolant: phosphate free (for Europe's high-mineral-content water), amine & nitrite/nitrate free (for USA long-life requirements), & low-silicate or silicate free (for Japan requirements) 50:50 mixture of ethylene glycol & water (the Bentleys say distilled water (Bentley 020-11), aka de-mineralized or de-ionized water, some call it purified water, and the BMW AG TIS 12.11.2007 18:56 specifies water with a pH from 6.5 to 8.0, maximum total hardness of 3.6 mmol Ca++/liter, maximum chloride content 100 mg/liter, and maximum sulphate content 100mg/liter; interestingly the BMW TIS says "potable tap water usually fulfills these requirements". EPA reports show San Jose & NYC tap water easily fulfill these requirements. The BMW TIS expressly states additives are not helpful and are not recommended. BMW lists a score of recommended coolants in their BMW AG TIS 12.11.2007 18:55 which meet the BMW N 600 69.0 standard, some of which are BMW PN:81.22.9.407.454 1.5-liter; BMW PN:88.88.6.900.316 1 gallon; Castrol Anti-Freeze NF; BASF Glysantin Protect Plus G48, & Havoline AFC (BD04); but most of which are not easily found in the USA. Many Bimmerfesters recommend BMW coolant; however other Bimmerfesters recommend Prestone Extended Life 5/150, Valvoline Zerex G-05, and Service Pro Universal Formula. Others (e.g., chiefwej, aioros), have tested Evans NPG+ but be aware propanol entails a different maintenance philosophy than the aqueous fluids listed above and is not compatible with them. [Total Volume: 1997 I6=10.5 quarts (2.6 gallons), 1997 V8=12.0 quarts (3.0 gallons), 1998-2002 I6=11.1 quarts (2.8 gallons), 1998-2002 V8=12.7 quarts (3.2 gallons), 1997-2002 V8 with latent heater=13.5 quarts (3.4 gallons)]. Prestone says the only reason for phosphate free is the extremely high mineral content of water in Europe - and that in the USA, it's not needed. Replacement Interval: Every three years (Bentley page 020-9) or every four years (aforementioned BMW AG TIS) starting from date of manufacture (except for M-Power vehicles which have 3-year intervals). Note: Mixing BMW-recommended coolant brands is permissible; but mixing types is not permissible unless it's an emergency.
