Old 05-19-2016, 10:24 AM
Raptor5 Raptor5 is offline
Mein Auto: BMW 550i
At my wits end with my headlight
OK guys I drive a 550I (2006). A Couple weeks ago my adaptive headlight warning came on and I took it to the stealership for a 150.00 diagnostic. They told me the passenger headlight was kaput and I needed a new one to the tune of 2900.00 (Whee!!!!).
I vosited EBay and found an assembly from Hella that was listed as compatible with my model. and I ordered it. When it got here, not only did it not have the control module, but no ballast either. The final insult was no low beam bulb. Although the control module will bolt right up from the old assembly, the ballast will NOT and I had to order another ballast. More of a concern is that the new assembly low light socket is ENTIRELY different than the old light and the wire hookup is as well. It will not accept the DS2 bulb at all!!
What can I do?? Is this the correct part or not??? Even the new DS1 bulb will not fit this goofy socket!! If it did, there would be a color difference between the lights!!
The fist three pics are the old light with the DS2 bulb. The last two pics are the new assembly and hookup.
Help! Help!
ID:	563768   Click image for larger version
ID:	563769   Click image for larger version
ID:	563770   Click image for larger version
ID:	563771   Click image for larger version
Old 05-19-2016, 12:43 PM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530
deleted
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 10+ Years
Old 05-20-2016, 06:36 AM
srschang srschang is offline
Mein Auto: 528xi
For about $1100, you could buy the OEM headlight (without the ballast & bulb). Not sure how much you paid for the wrong one on Ebay, but it wouldn't be worth the hassle to me. I'd send it back & order the OEM part from the cheapest online source, which using BMW PNPC looks like The BMW Parts Store
Old 05-20-2016, 07:54 AM
txag_530i's Avatar
txag_530i txag_530i is offline
Mein Auto: 2006 530i
What is the part number of the "new" headlight assembly? There is a difference between the pre-LCI and LCI headlights. IIRC, the LCI headlights use an electronic gate at the Xenon bulb to allow the high beams to work. The pre-LCI headlights use a halogen bulb for the high beams.
Check the part number with the Hella catalog and see if you were shipped the correct assembly.
And again I'll write it, don't buy car parts off of eBay unless you know the seller and they have a stellar rating and an easy return policy.
