E34 (1989 - 1995)
Old 09-13-2011, 02:24 AM
kurtis565 kurtis565 is offline
Mein Auto: BMW 5.25i
Unhappy 1990 BMW 5.25i wont start
So today i tried to start my 1990 BMW 5.25i, but the car wouldnt start! I found this very odd because the battery was fully charged but the engine made no sound at all. The only things that i had power to throughout my whole car were the interior lights (above rear veiw mirror), the hazard lights and a few of the dash lights (abs, fuel, battery) Any useful suggestions are much appreciated.
Old 09-13-2011, 06:26 AM
injunmort injunmort is offline
Mein Auto: 1990 525, 1991 535
need more info. does the car crank and not start? does nothing happen when you turn the key? are you sure the battery is fully charged? more info please. interior lights, radio etc are not an indication of a charged battery.
Old 09-13-2011, 06:13 PM
The car does not crank when i try to start it, I figure the battery is fully charged because I first thought that it might just be the battery so I put it onto a charger and the charger indicated that the battery was fully charged.
Old 09-13-2011, 06:14 PM
When i turn the key the only thing that happens is a small noise coming from the fuse box and a few dash lights light up
Old 09-13-2011, 07:06 PM
I just jumped started it and it fired right up. We tested the battery and it is fully charged and the alternator is in perfect working condition
Old 09-13-2011, 07:17 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Did you just test volts? It sounds like the battery needs to be load tested at a local auto parts store. If the amps are low, it will not crank.
Hope this helps.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-14-2011, 05:30 AM
clean your grounds and you might have a flat spot in the starter.
Old 11-17-2012, 12:57 AM
sdiaz1190 sdiaz1190 is offline
Mein Auto: 1990 bmw 735i
I am also having this problem with my 1990 735i
Sent from my Desire HD using Bimmer App
