Case study: Low-voltage dead instrument cluster - no alphanumerics & most gauges inop - Page 2 - Bimmerfest - BMW Forums
Old 09-19-2011, 11:33 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
The electronics in these cars are very sensitive to battery voltage. As the battery died, the systems did not shut down in an orderly fashion. The new battery reset the systems.
Think about pulling the plug on your PC w/o shutting down the OS. Things get funky when you next boot up.
Old 09-19-2011, 11:52 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I wonder if the decades-old battery charger had something to do with this, since I don't know of others who had the same symptoms ...
The strange thing is that the battery was still good enough to easily start the car quite a few times (after it was charged on the car when I first left the key in the ignition) and there was never a warning lamp.
I even used up a half tank of gas in the past four days with the cluster almost totally dead the whole time.
I'm wondering why we don't see this more often?
Anyway, I'm supremely thankful for all your help in my time of need! Thanks to you all!
Here's a pic of rush-hour traffic on highway 85 in San Jose today. Oh blessed alphanumerics!
The data I missed most was the fuel gauge & the odometer (because I couldn't tell if I had any fuel left)!
Old 09-20-2011, 03:53 AM
Flybot's Avatar
Flybot Flybot is offline
Mein Auto: '98 528
Low voltage
Old 09-20-2011, 06:40 AM
Fudman's Avatar
Fudman Fudman is offline
Originally Posted by bluebee View Post
So the question becomes, WHY/HOW could a battery that suddenly (and without warning) "went bad" cause 'just' the following units to suddenly stop working completely?
Glad to hear the battery fixed the problem. When it comes to electrical and software issues, my experience is that it is often better not to ask WHY/HOW since the folks that developed the system don't know the why or how either.
And the speedo is typically mechanically cable driven and not electrical.
Old 09-20-2011, 07:22 AM
bimmerteck bimmerteck is offline
BMW Magician
Mein Auto: e30 M50ish
The last BMW with a cable driven speedo was an e21. (1983 320i)
Old 09-20-2011, 08:01 AM
Fudman's Avatar
That was my previous BMW (1980 e21)!
Old 09-20-2011, 09:54 AM
bluebee's Avatar
For the future, a 'diagnostic' hint may be the particular voltage-sensitive controls that are affected ...
For example, if someone reports a tach & alphanumerics out and an intermittent fuel gauge but the speedometer and temperature gauge or manifold vacuum gauge working, we could 'suspect' low voltage:
To start the diagnostic tree ... my hypothetical assumption, for future diagnostic purposes, is thus:
  • The tachometer is much more sensitive to low voltage than the speedometer is ...
  • The fuel gauge is somewhat more sensitive to low voltage than the temperature gauge or manifold vacuum gauge is ...
  • The TIME alphanumerics on the MID are much more sensitive to low voltage than the RADIO alphanumerics are ...
Old 09-20-2011, 10:15 AM
BMW Magician
To start the diagnostic tree ... my hypothetical assumption, [B]for future diagnostic purposes
What acts up first when voltage drops varies greatly from instance to instance, car to car, and rarely has any discernible pattern to it other than the complaint being "electronics are acting up".
It would be best to simply state:
In the case of seemingly faulty electronics in any BMW, one should first verify the integrity of both the charging system and battery before proceeding with further diagnostics.
It will take you more time looking for and then reading your "simple" diagnostic tree post than it will to simply grab a meter and check both components.
Good advice is always certain to be ignored, but that's no reason not to give it.
Local to TN? TNeuros - Praise the lowered? Stanceworks
Old 09-20-2011, 12:44 PM
Flybot's Avatar
Mein Auto: '98 528
Agreed. You cant say at 11.8 volts this happens, at 11.7 volts that happens, etc. Its just Low Voltage, in general, will cause electrical faults, in general. Test system voltage (battery, alternator).
Old 09-21-2011, 02:20 AM
Whorse Whorse is offline
Mein Auto: e30, e39
good to hear a new battery solved your problem, i really thought u did alot of damage to the electronics with the key turned on. (i couldn't bring myself to tell ya that)
Andreas
Queens NY
BMWCCA# 186796
86 325es (wrecked by careless driver)
87 325 300k (project for life) aka 1BADETA/Christine
89 525i 190k Winter/Drift Poutana
00 540is 6spd 223k (daily driver) new motor at 214k due to chain guide failure
Old 09-21-2011, 05:30 AM
bluebee's Avatar
I did too!
The fact that the cluster was suddenly so very dead coupled with the car starting fine, didn't lead me to believe it was the battery (until I had tested it) - especially since I had charged the battery and it started the car up just fine - and drove for a half tank of gas - so the alternator was sure to be working.
Add the fact that the MID was out, and I was pretty sure it could be an expensive module that was kaput.
I started bemoaning the fact I used a 25-year old full-wave-rectified non-solid-state charger on a 'modern' vehicle, and/or the fact I hadn't waited the requisite 16 minutes nor did I disconnect the battery prior to charging.
I didn't 'think' I left the key in during the charging operation - and - I 'did' use the engine-bay battery connections ... but who knew if the ancient charger was malfunctioning, especially when it was pegged at >6amps (and who knew how many volts at the time).
My main hope, of course, was that it was just a blown fuse; but I didn't really think there was, for example, a single fuse for the TIME component of both the cluster & the MID ... so I too was sure there was a good chance that an expensive CPU was fried.
In fact, truth be told, I was as shocked to see the display suddenly come back as I was to see the cluster almost entirely dead!
The good news is that you guys were right on the money with 'low voltage' being the suspected culprit - even though the car started just fine (and, of course, I rued the fact I couldn't see any warnings on the display, if there were any).
Whew! Close call!
Right now, after almost two years of not working, I don't need capital expenditures. My main problem is that I can't afford the lifestyle I'm living ... i.e., my friends tell me I'm just 'playing retired' ...
But, I sure am enjoying spending my days in the Santa Cruz mountains, hiking the trails, hitting the beach (we called it the 'shore' back east but they call it the 'beach' here), laying back, and living the good life (for as long as it lasts).
Thank you ALL for being there when I needed you!
Old 12-03-2011, 06:33 PM
bluebee's Avatar
For the record, a similar half-dead instrument cluster issue popped up today:
- E39 (1997 - 2003) > Got back from shop, Tachometer/MPG non-functional
Originally Posted by aspensilver540 View Post
...Tachometer and MPG gauges just sat at 0 and max mpg, never moving. The OBC, mph still work as normal. The other dash lights seem normal except the brake fluid light is on.
For which, it was suggested:
Originally Posted by windsmith View Post
I've seen weird stuff like this fixed by simply disconnecting the battery for a few hours.
And, for which the OP just updated:
Yup, that did it, thanks! 30 minutes disconnected, who knows if the time matters. I bet 1-2 minutes would have been the same result.
Old 02-28-2012, 08:00 AM
bluebee's Avatar
Just in case someone comes here looking for help with their cluster issues, here is a thread posted today which seems similar, at least with respect to initial symptoms:
> E39 (1997 - 2003) > 1997 BMW Cluster Stopped Working!!!
Originally Posted by veco View Post
... my cluster stopped working.
The main parts that don't work are the trip meter, speedometer, tachometer, temp gauge, fuel gauge, and other little dashboard lights that don't turn on.
But the parts that function properly are the turn signal lights, high beam lights, fog lights, oil service lights, gear position lights(car is auto), etc.
There is one light that is constantly on, the seatbelt light. It stays on even though I'm wearing my seatbelt and the only light that works on command is the ASC light.
I looked up some forums but i only found one where they said it could be a bad battery causing the problem but im not so sure because my car turns on and runs perfectly.
Here is a video i took a few hours ago showing the problem. notice @0:43 how i rev the engine a little and the tachometer doesnt even budge.
Old 06-12-2012, 10:31 PM
tarokyama tarokyama is offline
Mein Auto: 2000 528i
Bluebee, I am having very similar problems as you,
I replaced my ignition switch, as well as put in a new battery,
checked all fuses. I also swapped the unloader relay,
still no gauges, it was intermittent at first, but now
no guages at all, and no radio, I think it may be important to
note that my horn IS working, which eliminates the slip ring as the problem.
any other ideas?
Old 06-13-2012, 08:36 PM
BMWgovernor BMWgovernor is offline
BMW governor
Mein Auto: 2000 BMW 528i M
Post Dead Instr. Panel possiblities
Check to see if your car has (batteries located in/on the back of the instr. panel). They could be low or dead. This could be your problem.
Remove the instr. panel. you should see an area with a battery or batteries. BEFORE you rip your car apart.
Check with your local BMW parts dlr. give them your VIN. they should be able to tell you if your dash panel requires addtl. battery power.
Last edited by BMWgovernor; 06-13-2012 at 08:40 PM. Reason: needed to be more specific and clear.
Old 06-14-2012, 07:12 PM
Instrument clusters have batteries in them?!?
I've never heard of this.
Old 12-04-2012, 11:23 PM
bluebee's Avatar
This came in today ... might be related to the same problem I had ...
Originally Posted by prsch956 View Post
I have this weird electrical problem with my e39 530i. When the car is powered on, the MID is off but the radio turns on. Radio then shuts down after 40 seconds. I'm not able to communicate with the OBC either. The dealership could not either. The DSC light came on about 2 hours before this and it's been on since but I'm not sure if they are related or not. Any suggestions?
I have the high OBC setup with a separate MID.
Thanks.
Old 04-04-2014, 06:12 PM
bluebee's Avatar
For the crosslinked record, this came in today:
> E39 (1997 - 2003) > Instrument cluster problem 528i e39
Originally Posted by Francis452 View Post
I have a 528i E39 and today, my speedometer stopped working, after 5 minutes the rpm gauge went down too and finally, when I restarted my car, the speedometer, rpm, engine temperature and fuel gauge were not working. My odometer, lightning and everything else is working. I have since a few months a abs and traction light. My battery is new. Do you have an idea of what it can be?
Old 04-05-2014, 04:24 PM
Aussie528iT Aussie528iT is offline
Mein Auto: 528iT
E39s don't have batteries in the instrument panel. Early cars E30s etc (circa late 80s) did but later BMWs don't have instrument panel batteries.
RonR
Old 12-21-2014, 02:15 PM
bluebee's Avatar
Another instrument cluster gone crazy reported over here today ...
> E39 (1997 - 2003) > instrument cluster goes crazy
Originally Posted by gvelco View Post
sometimes(exceptionally on cold start)my instrument cluster goes wrong,for example it shows water needle on red mark,trans failsafe prog icon,tachometer needle stucks.restart engine cures this problem.
what's up?
Old 01-08-2015, 10:33 AM
bluebee's Avatar
Another example today of electrical problems doing funny things to the instrument cluster ...
> E39 (1997 - 2003) > E39 Instrument Cluster Problems e39 540iA
Originally Posted by Bue11er View Post
Greetings everyone! I am a new e39 owner (540iA) and my instrument cluster is not working properly. When I turn the car on, the fuel gauge will jump around a bit, the tachometer will jump up a bit, then slowly flick back down, and the speedometer won't read. I have heard the fix about the wheel speed sensor going out and needing replaced - but this is all my gauges that are responding erratically. What could it be? Is it the instrument cluster itself? Can it be repaired or do I need to buy a new one? Fuses? Wiring gone bad? If there is a thread dedicated to this problem already, please point me to it. I can't be the only one who has had this problem... Thank you for your help!
You were close. The alternator went out. I'm in the middle of replacing it right now. Have to see if that ends up solving the needles flicking also.
Old 01-09-2015, 03:03 AM
brc5 brc5 is offline
Mein Auto: 535i, 528iT
Good news! (audible sigh of relief!)
The seemingly complex & comprehensive cluster death (amazingly) was solved today (simply) by replacing the (bad) BMW battery!
- Pictorial discussion of charging, testing, removing, & replacing the BMW E39 battery
Here is a pic, taken today, as I breezed along highway 85 in San Jose. The tach & fuel gauge & alphanumerics were all suddenly back in operation!
Even the MID time display returned!
Whew!
- The tachometer was totally dead (speedo was fine)
- There were absolutely no alphanumerics on the cluster (and most indicator lights were also dead)
- The MID time alphanumerics were totally gone (but other alphanumerics were fine)
- The blue high beam indicator went inoperative (but turn indicators were fine)
- The gas gauge was inoperative most of the time (except for a brief interval in the middle, when it suddenly worked until I shut down the vehicle)
All electronics are sensitive to voltages. Insufficient or excess voltage can cause all sorts of problems.
I know of a car in which the auto box kept going into limp home mode. An auto specialist said it was busted and needed a rebuild. This was done at great expense and yet, the problem continued to happen after the rebuild. One of the fault codes was a voltage input code. On a whim, a new battery was dropped in. This permanently fixed the auto problem.
It's likely the IKE has some type of low voltage cutoff that prevents it from working. Whenever there is a suspect battery, replace it before anything else.
Do you know how fast your E39 is?
Old 04-05-2015, 08:07 PM
bluebee's Avatar
In this thread today was another problem caused by the battery being in just the wrong voltage for the instrument cluster:
> E39 (1997 - 2003) > seat twist issue-which motor controls seat height?
Originally Posted by 540iman View Post
Maybe after I solve my very odd electrical issues with my instrument cluster, I will re-attack
VERY interesting answer to someone with same instrument cluster issues I have. Read OP and then go to post #9 and beyond...
http://www.m5board.com/vbulletin/e39...sn-t-work.html
All my instrument "gremlins" are gone with a hard reset. Removed battery cables and shorted them together. Put battery on a slow charge, but it was reading 12.34VDC before hooking it up to charger so really don't think battery was the issue I believe issue was battery was low, starting to come back being on Charger and then WHAM I cranked car and it started. IKE module likely was at lower voltage at that point and selectively hung up. After shorting cables and charging battery, I hooked cables back up and all gauges and displays were back to normal. PHEW...
Old 04-05-2015, 08:51 PM
emaN laeR emaN laeR is offline
Mein Auto: Quattro
Let me add a few cents to the “battery” and gremlins.
Primarily, I work on Euro headaches and every one of them is either different or repeating issues.
With a power supply issue, follow these steps:
Test the battery with a carbon pile and ensure the tests fits the category of the installed battery.
If it fails, replace it.
Now are the issues.
When I replace a battery and know full well the vehicle have many customer adaptations, the battery is replaced HOT!
Added either in a power socket (alive at all times) or DLC is a power pack fully charged. Take note that the cables are now HOT! Ask for a second hand or insulate the terminals.
Replace the battery, remove the second battery (register is required)
Measure the voltage drop at ALL battery connections B+ and B- (repair all defective connections if found)
Attach a power (clean and NO A/C ripple) and scan the entire vehicle. Address all faults later.
Remove the power supply and start the vehicle
Test the charging system as per BMW specifications. It must pass. Replace or repair if required.
Use an AMP clamp and load tester to acquire the correct readings.
Shut down the vehicle and attach the power supply, rescan and address all faults.
Remove the scan tool, road test and scan again after a drive cycle. Address all faults again.
For a draw, open the front doors, hood and trunk. Latch everything but don’t lock the vehicle.
Let the network go to sleep, have a low current AMP clamp attached to the B- cable and measure the draw. 50ma is a nice number depending on the amount of networks and how quickly they go to sleep.
If a draw is found, DO NOT remove any fuses, that may reset a defect. Measure the fuses with a multi-meter using the scales included.
If poor connections are found (voltage drops etc) it would be smart to invest in a load pro. It does the calculation on the meter while under load. That doesn’t mean the CAN connections are measure in that way. CAN connections are measured with an oscilloscope or CAN analyzer to “sniff” network activity.
Begin with powers and grounds first.
Old 04-06-2015, 06:07 AM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
Just for reference, a car battery charger often puts out 15+ VDC unloaded. This is what gives it the "quick charge" ability. Your charger Bee putting out 12.5 volts is just fine, but indicates a full charge will take a longer time. It is the unloaded voltage differential between object needing charge at full output and what is charging it that determines time necessary to achieve full charge. Same for all chargers-like wall jacks for phones, etc. Once hooked up to a load (the battery) the battery will then dictate the system voltage. A 12 volt battery with a charger putting out even 18 volts will read 12volts when connected to a load. You should never remove a battery and then try to start a car directly off a charger even if charger is very large and can put out enough amps to start a car. You must have a load or battery in circuit to bring charger voltage down to your battery working voltage. I hear you can also pull fuses 18-24-40 put ignition switch to position #1 and then push fuses for instrument cluster back in and the I/C will correct itself.
battery charging, cluster, fuses, mid display
