Old 09-16-2011, 11:59 AM
mscamp's Avatar
mscamp mscamp is offline
Bimmer Dreamer
Mein Auto: 2011 X3
Instrument Cluster Reset
Had the battery drain down while having windows tinted. Jump start was fine except that now all the gauges are messed up. Dealer explains that they will do a cluster reset and battery check. 2006 X3 w/ 65k miles. Probably time for a battery anyway.
Best car we have ever owned.
2011 X3 - Purchased BMW of Peoria, IL October 6, 2012 - Deep Sea Blue/Oyster/Sienna - CWP1, CWP2, TP, PP, CP, PDC.
2006 X3 - Purchased BMW of Peoria, IL September 10, 2007 - Black/Black (Retired)
2006 330i Purchased BMW of Peoria, IL October 12, 2005 Arctic Met/Beige (Retired)
Old 09-18-2011, 12:51 PM
mscamp's Avatar
Bimmer Dreamer
Mein Auto: 2011 X3
Seems to be healing itself. Everything is pretty much back to normal.
Old 08-12-2012, 06:03 PM
cybercord cybercord is offline
Mein Auto: M Roadster
Thumbs up Cluster reset
Had the same problem today. The cluster was not showing anything. But the radio and memroy settings still worked. I looked into the fuses as possible. Removed the 3 that are releated to the display, 5, 34, and 43. After pulling and replacing 43 I heard some sounds inside the car. Put the key into the car , then to pos 2 and had a mess. But cluster lights are on. Drove a little and then all things started to come back. Cheaper than taking to the dealer.
Good Luck
Al
Old 08-13-2012, 10:57 AM
littleengin littleengin is offline
Mein Auto: 2006 X3 M-Sport
Had the same symptoms after replacing the battery. Checked the fuses and I had one blown. Replaced it and everything is back to normal.
Old 11-06-2013, 11:17 AM
sgt118 sgt118 is offline
Mein Auto: 2001 BMW 330I
cluster messed up...
I had a battery and alternator changed out yesterday. Went to drive the car and some of the gauges don't go back to starting all the way and trip resets all the time and clock does the same, any info will be very thankfull.
