Old 04-05-2011, 06:20 AM
Almondus Almondus is offline
Mein Auto: 1996 735iL
03 745Li - Trunk problems
From my research around this I understand that the trunk functions can be disabled when there is an electrical disruption. This can be rectified by:
1. triggering the latch manually, by using a hard object to close the latch.
Then either:
2. unlocking the latch with the small manual lever (on the catch mechanism)
Or
3. Activating the key fob trunk unlock button.
I have a similar trunk problem, ie. Need to use the key manually, but mine problem began spontaneously: no electrical disruption, so I'm still stuck!
Hope this helps!
Al
Old 08-08-2011, 11:15 AM
yamein1212 yamein1212 is offline
DoingAllright
Mein Auto: 2003 745li
Help with trunk
Originally Posted by BRIGADA View Post
Guys, if anyone needs help just reply
Figured I would reply. My trunk does not close all the way it goes down a little but never fully suctions in. DId you have a fix for this? Thanks in advance...
Old 09-17-2011, 12:14 PM
ilbruns ilbruns is offline
Mein Auto: 745i
Thumbs up E65 Trunck Release
Read the threads and never even thought about the center console/armrest. checked the switch and it was on lock. flipped the switch to unlock and pushed the button and it worked. I was thinking fuse but every time I used the key the electric release made noise so assumed power to it. I was getting ready to tear into it, but searched here first.
Thanks for the note of the switch as I was embarrassed having to turn off the car to get out and open the trunk with a key.
THANK YOU!!!!!
