Old 01-10-2012, 12:37 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
As far as I'm concerned, and my tranny - 5HP19- the Trade Name 11B fluids
Old 01-10-2012, 05:48 AM
Fudman's Avatar
Fudman Fudman is online now
Originally Posted by Blight67 View Post
Pentosin ATF1 is the only full synthetic that I came across that meets LT71141. Attached are the product sheets for the Pentosin, Castrol, and ESSO products.
My indy highly recommended the Pentosin due to it being a full synthetic. In my case, that was the main reason for paying more for the Pentosin.
I guess the question is then what does it mean to be LT71141 compliant.
The real question is not which ATF is most similar to ESSO LT71141 but rather should be what ATF (performance characteristics) does ZF require for their trannys. The attached .pdfs only describe the physical characteristics of each ATF. And a comparison indicates different levels of performance. However, both refer to ZF TE ML, 11B or Zf te-.ml11, 14. I believe these documents will identify the minimum performance characteristics that are required of the ATF to be used in the ZF tranny. While the auto manufacturer identifies ATF recommendations, ultimately, it is the tranny manufacturer that knows most about their product and which ATF to use.
As with most products, there appears to be a range of performance characteristics that are acceptable for use. Hence, I would not sweat it regarding which is the "best" ATF to use. Much like motor oil, adequate (to mean meets minimum requirements) is an acceptable solution. And like motor oil, more frequent change intervals is probably more important to reducing wear than the type of ATF when left in for extended durations. When it comes to lubricants, there should be no perceptible performance difference created by using lubricants within the required range of performance. The primary benefit would be in extended service intervals.
Old 01-10-2012, 09:16 AM
Blight67 Blight67 is offline
Mein Auto: 2002 530i Sport Pkg
I didn't mean to imply that one ATF was better (performance-wise) over another. The specs were attached primarily to provide the documentation that the Pentosin is the only full synthetic of the bunch I examined. I'm sure that if they meet the ZF TE-ML 11B spec, they will perform just fine in the ZF tranny. Likewise, since ZF selected ESSO as the OE ATF, an ATF meeting LT71141 should be fine as well. In all the cases besides ESSO, it comes down to the ATF manufacturer standing behind their product for this application. ESSO is a special cases since I'm sure that ZF performed their initial testing with it.
I prefer to go with the Pentosin since I believe that a full synthetic will do better in extended service interval usage, especially in high-pressure, high-temperature environments.
[edit] Not that this means anything, but I just noticed that Castrol IMV ATF claims support for LL71141 but not ZF TE-MT 11B spec.
Old 01-10-2012, 10:47 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
I would place more emphasis on what BMW says to use vs. ZF tranny, and here's my argument for it. Just like adhering to BMW's tire psi vs. the tire mfr's max psi, the automaker ultimately controls the application side of the product, even though the product isn't made by BMW. When the trans gets installed into the various cars, BMW may opt to do this and that, sometimes just tweaking the shift programming, other times incorporating a different sprag or springs within the valve body, to get the desired feel and performance out of that type transmission. Thus, the formulation of the fluid may be different than what ZF might have speficied initially in order to exact the characteristics that BMW seeks. in addition to viscosity characteristics, there's also the friction coefficient that has to be looked at with the ATF. Unfortunately, the latter is rarely provided, if any, even though fluid friction coefficient is one very important criteria for the clutches to work optimally. If the fluid is too slippery, the clutches will overheat, not enough slip, the bands around the clutch packs prematurely fails. The ATF has to slip just right for a given trans, and like stated earlier, BMW ultimately controls how the trans is to perform.
If it were me, I'd just pay the coin and use what BMW says to use.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 01-10-2012, 10:59 AM
Fudman's Avatar
Sorry, Blight, I didn't mean to imply it was you who was referring to "best" ATF. It just seems that every other thread is from someone asking about what is the "best oil" or "best ATF" or "best PS fluid" to use. My view is there is no "best" of anything (which is just an opinion). It all depends on what your needs are. For instance, if you don't need low temperature starting and are willing to change out your oil regularly, old fashioned "dino" motor oil is every bit as good as synthetic at a lower cost.
The intent of my original post was to simply identify lower cost alternatives to ESSO. While some have no issue with going with what is recommended and others are willing to pay more for "improved" performance, I fall in the "What is the cheapest that will work the same" camp. I'd rather spend my money on a good bottle of bourbon or wine where I can taste the difference!
Old 01-10-2012, 11:16 AM
Jason5driver's Avatar
Jason5driver Jason5driver is online now
Mein Auto: E39 hamster w/ pin-wheel
This.:
http://www.amsoil.com/storefront/atf.aspx
Old 01-10-2012, 04:38 PM
No worries Fudman.
This all started as a researching exercise for my own ATF change. The e39 wiki only mentions the Castrol ATF with a link to this thread. My initial post was intended to ensure that people don't blindly go with the LT71141 without knowing the other possible e39 ATF's that might be required.
With all the confusion about ATF, the point was just to ensure that everyone is making informed decisions about what they put into their tranny. I didn't realize that the discussion would evolve into a what's best discussion.
Old 01-10-2012, 04:43 PM
Jason5driver,
I don't know if Amsoil can be recommended since it carried neither the ESSO LT71141 nor the ZF TE-ML 11b certifications. It only carries certifications for the ZF 5HP30 found on certain the e31, e32, and e34 cars.
Old 03-20-2013, 01:13 PM
Studawg's Avatar
Studawg Studawg is offline
Mein Auto: 2003 540iT M Sport
update
I purchased some Valvoline Max Life ATF fluid because Im about to do a fluid change, and it said on the back of the bottle that it is recommended for use in applications using the BMW LT71141. Then I read some conflicting info in this thread. So then I went to the website and it doesnt list the BMW LT71141 on the spec sheet. So its on the bottle, but not on the website. So I called the Valvoline hotline on the bottle, (1800TEAMVAL) and spoke to a Valvoline product technician. He confirms that this fluid IS an "exact substitute for the LT71141." He said the the website is in the process of being updated and is not current. As of right now, according to a Valvoline product technician, the Valvoline MAX LIFE Dex/Merc that has BMW LT71141 on the product label, is an "exact substitute" for the LT71141.
By the way, this fluid is a "Synthetic base", which I assume is a synthetic blend, as is the original Esso/Pentosin fluid.
2003 540iT M Sport, Black Sapphire Metallic/Black leather, CWP, DSP, rear shades, Climate Comfort windshield
1988 325i 4dr/ 5Sp, Lachssilber Metallic/Black Leather
Old 06-27-2014, 08:42 PM
BeemRat BeemRat is offline
Mein Auto: 530i
Arrow January 2014 ZF list of approved transmission fluids
The list of lubricants TE-ML 11, Edition 01.04.2014 replaces all previous editions. The current list can be requested from any ZF after-sales service center or accessed on the Internet under www.zf.com/lubricants.
2003 530i Sport M-Tech
Old 06-28-2014, 02:27 AM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is online now
Mein Auto: 01' 540 M-Sport, Scuderia
BTW, factory ZF Lifeguard 5 is available in 1 liter bottles from Bavarian Auto for $16.95 each. I've used it for my last two changes (been doing 30k since new), previously I used the Esso, later relabeled Mobil, LT71141.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, Bilstein B14 PSS coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 06-28-2014, 01:35 PM
GreenTiger GreenTiger is offline
Mein Auto: 7/98 NonVanos 540iA
What is the difference between the 11A and 11B fluids?
"It's not about how fast you can go. Its about how fast you get to fast."
-Torque
Old 06-29-2014, 01:11 PM
Mein Auto: 530i
Post ZF 11A and 11B specs
The 11B is described as "longer life fluid." Here is a decent discussion (links are dead):
http://www.meurosport.com/ZF_Transmission_Fluid.php
"...oil (trans fluid) change on automatic transmissions is recommended between 80,000 km and 120,000 km or 8 years, depending on the load. In each case, only released ATF oil may be used for oil changes. And oil changes must be performed in accordance with the relevant specifications."
Old 06-29-2014, 06:26 PM
So the 11b is compatible with the 5hp24?
-Torque
Old 05-01-2015, 04:20 PM
PoormanSon PoormanSon is offline
Mein Auto: VW Rialta Eurovan
Valvoline Maxlife Specs
Originally Posted by bmw_n00b13 View Post
Valvoline MaxLife ATF claims compatibility with that fluid. I'd show you the package but my wife cleaned it up and I don't know where it is
I talked with Castrol, Pennzoil and Valvoline today. The only one of these that makes a FULL SYNTHETIC ATF that is compatible with LT71141 is Valvoline. It is Maxlife. He emailed this:
THOMAS R. SMITH
Vice President, Branded Lubricant Technology
November 20, 2014
To Whom It May Concern:
MaxLife ATF is a full synthetic automatic transmission fluid designed to meet the needs of the broadest range of transmission designs. MaxLife ATF recommendations are based on a combination of field-testing and laboratory testing.
Valvoline recommends MaxLife ATF in a broad range of transmissions. The list below is just a sample of applications where Valvoline supports the use of MaxLife ATF. Valvoline has conducted in-house testing, independent lab testing, and field-testing to support MaxLife ATF performance in these transmissions; however, it is important to note that the respective vehicle manufacturers have neither evaluated nor approved MaxLife ATF in these applications.
• Allison TES 389, C-4
• Audi/VW G-055-025-A2, G-052-162-A1/A2, G-052-990-A2, G-055-005-A2, G-055-162-A6, G-055-540-A2, G-060-162-A2
• BMW LT71141, LA2634, M-1375.4 fluids
• Chrysler Diamond SP-III, NAG-1, 3403 M115
• Ford MERCON***63720;
• Ford FNR5
• Ford MERCON® V
• Ford XL-12
• Ford MERCON® SP
• MERCON® LV
• GM 9986195
• GM DEXRON® II, III and VI
• GM Autotrak II
• Honda/Acura ATF-Z1, DW1 (except in CVTs)
• Hyundai SP-II, SP-III, SP-IV, SPH-IV, SP4-M
• JWS 3309
• JASO 1A
• KIA SP-II and SP-III Fluids
• KIA Red 1
• Mazda M-V, FZ
• Mercedes Benz MB236.1, MB236.6, MB236.7, MB236.9, MB236.10, MB236.12, MB 236.14, MB 236.15
• Mercedes Benz NAG-1
• MOPAR AS68RC ATF
• Miscellaneous OEMs – M1375.4, M1375.6, L12108, LT 71141, ETL-7045E, ETL-8072B, 3403 M115, N402, AW-1
• Mitsubishi Diamond SP-II, SP-III, ATF-J3
• Nissan Matic-D, Matic-J, Matic-K, Matic-S, Matic W
• Saab 93 165 147
• Subaru ATF
• Subaru ATF-HP
• Toyota / Lexus Type T, T-III and T-IV
• Toyota WS
• Volvo 1161521 and 1161540, and STD 1273.41
• VW TL52162, LT71141
• ZF TE-ML-14B, 16L, 17C
Valvoline stands behind all of its products, including MaxLife ATF. Use of MaxLife ATF in transmissions where recommended by Valvoline WILL NOT void the vehicle's warranty. Vehicle manufacturers are restricted by federal law from including the requirement of the use of a specific brand or trade name of product or service as a condition of their warranty. The following is an extract from the Federal Trade Commission's web site on interpretation of the Magnuson-Moss Warranty Act:
"Tie-In Sales" Provisions Generally, tie-in sales provisions are not allowed. Such a provision would require a purchaser of the warranted product to buy an item or service from a particular company to use with the warranted product in order to be eligible to receive a remedy under the warranty. The following are examples of prohibited tie-in sales provisions.
In order to keep your new Plenum Brand Vacuum Cleaner warranty in effect, you must use genuine Plenum Brand Filter Bags. Failure to have
scheduled maintenance performed, at your expense, by the Great American Maintenance Company, Inc., voids this warranty.
Valvoline has conducted extensive testing and has a long history of successful use of MaxLife ATF in a broad range of applications. In the unlikely event that you or your customer experiences any transmission damage while using MaxLife ATF in a Valvoline recommended application, please contact Valvoline at 1-800-Team-VAL for assistance.
While MaxLife ATF is designed to meet the special needs of higher mileage transmissions, new transmissions can also benefit from its enhanced oxidation protection, shear stability, seal compatibility, wear protection and anti-shudder protection. Many consumers have chosen to take advantage of this level of performance in newer transmissions.
Valvoline does not recommend MaxLife ATF for use in most continuously variable transmissions (CVTs) unless specifically noted nor in automatic transmissions where Ford Type F fluids are recommended.
Sincerely,
Thom Smith
Vice President, Lubricant Technology
Valvoline
