E28 (1982 - 1988)
Tachometer and onborad computer won't work :mad:...
Hi there
I have a 88 528e which in the past has had the fuse connection for the tachometer, onboard computer and odometer go out (also the stereo, but another owner changed the original hook up I believe). I had repeatedly tried fuses and working with the connections, but as of late, I think it might be done. Does anyone have a troubleshooting idea? Thanks for any suggestions. Ken Wood |
Don't be gormless; get some gorm! ![/I][/FONT] |
Thank you Catso, I will look into the wiring. That sounds very logical. In the past I have jiggled or moved the fuse and it works fine. Now, nothing.
The fuses and fuse holders are known problem areas. Sometimes a fuse looks good but still doesn't work due to a small crack, looseness, etc. Try changing the suspect fuses with new ones and clean the contact areas.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
